Found core loss equation, please explain
  • Thread starter Thread starter chopficaro
    Core Explain Loss
The core loss equation for magnetic materials is defined by two primary components: hysteresis loss and eddy current loss. Hysteresis loss is calculated using the formula Wh = k1.f.Bnmax, while eddy current loss is given by We = k2.f²t²Beff² / ρ. In these equations, constants k1 and k2 are material-specific, f represents frequency in Hz, Bmax is the maximum flux density in Tesla, and ρ denotes the resistivity of the material. The Steinmetz exponent, n, varies between 1.6 and 2.5 depending on the material properties.
  • Understanding of hysteresis loss in magnetic materials
  • Knowledge of eddy current loss calculations
  • Familiarity with magnetic flux density and its units (Tesla)
  • Basic principles of electromagnetic theory
  • Research the impact of the Steinmetz exponent on core loss calculations
  • Explore advanced materials that affect hysteresis and eddy current losses
  • Learn about the measurement techniques for magnetic flux density
  • Investigate the role of frequency in core loss performance
Electrical engineers, materials scientists, and anyone involved in the design and optimization of magnetic components in electrical devices.
chopficaro
this is the formula for calculating core loss
http://power.thayer.dartmouth.edu/pictures/function.jpg
alpha, beta and k are constants that have to do with the material of the core. what are f and B, and what exactly does Pcore mean
f is the frequency and B is the maximum applied magnetic field. The equation is a model of hysteresis loss.
http://hyperphysics.phy-astr.gsu.edu/hbase/solids/hyst.html"
Excuse me, but:
1- B is maximum flux density
2- That formula related to complex losses due to hysteresis and eddy current losses.
Indeed the components of core loss can be represented by the expressions below:
Hysteresis loss,
Wh = k1.f.Bnmax watts/kg
and Eddy current loss,
We = k2.f2t2B2eff / ρ watts/kg
where k1 and k2 are constants for the material
f is frequency, Hz
t is thickness of the material, mm
ρ is the resistivity of the material
Bmax is maximum flux density, T
Beff is the flux density corresponding to the r.m.s. value of the applied voltage
n is the ‘Steinmetz exponent’ which is a function of the material. Originally this was taken as 1.6 but with modern materials and higher flux densities n can vary from 1.6 to 2.5 or higher.
Creative thinking is breezy, Then think about your surrounding things and other thought products. http://electrical-riddles.com
  • · Replies 23 ·
24K
11K
