What exactly is an adjoint flux?
  • Thread starter Thread starter Uranium
    Flux
Adjoint flux is a critical concept in neutron transport theory, representing an importance factor for neutrons in radiation shielding and criticality analysis. It arises from the adjoint Boltzmann transport equation, which is derived by taking the adjoint of the Boltzmann transport equation operator. Utilizing adjoint flux as a weighting function enhances the accuracy of reactivity calculations to second order when applying first order perturbation theory. This method is essential for precise neutron behavior modeling in hybrid methods.
  • Understanding of the Boltzmann transport equation
  • Familiarity with perturbation theory in physics
  • Knowledge of matrix operations and adjoints
  • Basic concepts of neutron transport and criticality analysis
  • Study the derivation and applications of the adjoint Boltzmann transport equation
  • Explore advanced perturbation theory techniques in neutron transport
  • Investigate the role of adjoint flux in radiation shielding calculations
  • Learn about hybrid methods in neutron transport simulations
Researchers, nuclear engineers, and physicists involved in neutron transport theory, radiation shielding, and criticality safety assessments will benefit from this discussion.
Uranium
I've been reading a bit about hybrid methods, and I keep coming across adjoint fluxes. What exactly is an adjoint flux? And how does it factor into calculations?
Thanks,
Uranium
An adjoint calculation is basically a backwards calculation. Instead of starting with a neutron and calculating where it goes, you start with a fission event and calculate where the neutron that caused it could have come from.
Adjoint flux is basically an importance factor for neutrons, and it's useful for radiation shielding and criticality analysis.
Uranium,
Mathematical operators have "adjoints". For example, the adjoint of a real matrix is its
transpose. The adjoint of the derivative is its negative.
You can take the Boltzmann transport equation, and take the adjoint of each of its
terms, and you get the adjoint Boltzmann equation. The solution to this equation is
the adjoint flux.
There is a physical interpretation to the adjoint equation; the concept of neutron
"importance" obeys the adjoint equation.
When you define certain quantities like reactivity, you do so with a weighting function
in general. If you use the adjoint flux as your weighting function, then your calculation
of the quantity becomes accurate to second order instead of first order when you use
Let H be the Boltzmann transport equation operator, and H* is its adjoint.
We have then psi as the solution to the forward equation - H psi = 0
We also have (H*)(psi*) = 0.
Suppose H' = H + dH and psi' = psi + dpsi
<psi*| H' | psi'> = <psi*| H + dH | psi + dpsi > =
<psi*| H | psi > + <psi*| H | dpsi> + <psi*| dH | psi > + <psi*| dH | dpsi >
The first term is zero [ H psi = 0 ]. First order perturbation theory would have one
using the third term as the answer. But the second term which we can't evaluate without
solving the new system for dpsi is also first order. However, from the definition of adjoints;
<psi*|H|dpsi> = < psi* | H dpsi > = < H*psi*|dpsi> = 0 since H* psi* = 0
Therefore, if you use only the 3rd term as per first order perturbation theory - your
error - the 4 th term is 2nd order - it has a dH and a dpsi.
The other first order term vanishes if you weight with the adjoint.
Dr. Gregory Greenman
  • · Replies 0 ·
