ALL TITLE:Is k[x^2,x^3] a Dedekind domain?
  • Context: Graduate
  • Thread starter Thread starter sidm
The discussion revolves around whether the ring k[x^2,x^3] is a Dedekind domain. Participants explore its properties, including its Noetherian nature and dimension, while also considering its integral closure and prime ideals.
  • One participant argues that k[x^2,x^3] is not integrally closed and that its integral closure is k[x]. They propose a proof showing that it is Noetherian and has dimension 1, relying on the structure of ideals and modules.
  • Another participant presents an isomorphism k[x^2,x^3] = k[t,u]/(t^2-u^3) and states that the polynomial t^2-u^3 is irreducible, making its principal ideal prime, thus supporting the claim that the ring is Noetherian and of dimension 1.
  • A later reply acknowledges the isomorphism and discusses the implications for dimension theory, questioning whether every prime appears in a chain of length n in rings of dimension n.
  • Another participant comments on the fundamental nature of dimension theory in algebraic geometry and notes that polynomial rings over a field exhibit homogeneous properties regarding the lengths of maximal towers of ideals.
  • There is a suggestion to explore a reference book on commutative algebra for further understanding, though it is noted that commutative algebra may not be easily learned through textbooks alone.
Participants express differing views on the properties of k[x^2,x^3], particularly regarding its integral closure and whether it qualifies as a Dedekind domain. The discussion remains unresolved with multiple competing perspectives on its characteristics.
Some arguments depend on the definitions of Noetherian rings and prime ideals, and the discussion includes unresolved mathematical steps regarding the implications of dimension theory.
sidm
I need help.
So the obvious answer is no, because it's not integrally closed (incidentally it's integral closure is in fact k[x]. Here obviously k is a field. But I want to show that it is both noetherian and dimension 1 (nonzero prime ideals are maximal), here is my idea for a proof: (i immediately apologize for the fact that I've forgotten how to tex on this forum)
1) Noetherian: k[x^2]<R<k[x] and k[x] is a finitely generated k[x^2] module (i.e. 1 and x generate k[x] as a k[x^2]-module) thus it is a noetherian k[x^2]-module since it is therefore the quotient of a free k[x^2]-module of finite rank. So if we take I<R an ideal of R (i.e. a R-submodule of R) then it is also a k[x^2]-submodule of R and therefore of k[x], thus it must be finitely generated as k[x^2]-module and so a (k[x^2,x^3]=)R -module as well.
2) B=k[x^3]<k[x^2,x^3]=A, then let P be a prime in A then P' the contraction in B. Note that contractions of primes are always prime and since B is a PID (it is in fact euclidean*) as long as we can prove the contraction is nonzero maximality follows.
It is nonzero since A is integral over B: x^2 satisfies Z^3-(x^3)^2 a monic polynomial with coefficients in B. Then let c \in P \neq 0 we know that c satisfies a monic polynomial over B and so
c^n+b_{n-1}c^{n-1}+...+a_0=0, we can assume a_0\neq 0 for otherwise factor out by the largest power of c that divides this equation and use the fact that we're in an integral domain. Then c^n+...+ca_1=-a_0 \in P \cap B.
Then B/P' is a field, K, living inside the integral domain A/P. Clearly A/P is algebraic over K: let y^2 denote the image of x^2 then it satisfies the polynomial Z^3-(y^3)^2 with coefficients in K (note y^3 is the image of x^3 in K). Now to finish we prove an unrelated result:
3) Every integral domain (R) containing a field (K) over which it itself is algebraic is a field: Let b \in R be nonzero, then R is a n-dimensional K-space. So then 1,b,..,b^n are linearly dependent over K: k_0+k_1b...+k_nb^n=0 so that b(b^{n-1}k_n+...+k_1)=k_0, if k_0 is zero then the polynomial in in brackets is zero but the 1,...,b^{n-1} are linearly independent so the k_i's are all zero but we chose them not to be. So k_0 is nonzero and in K and thus b has an inverse in B.
If someone could check my argument I would appreciate it, a simpler one would be nice too. A side note: I'm currently teaching myself algebraic number theory (using James Milne's notes) and if anyone would like to work with me let me know!
SM
Consider that [itex]k[x^2,x^3] = k[t,u]/(t^2-u^3).[/itex] The polynomial [itex]t^2-u^3[/itex] is irreducible, so it's principle ideal is prime.
Then, your ring is noetherian and dimension 1.
thanks! I had that exact isomorphism in mind though I abandoned it because for some reason or another I thought it was false! Now however it's clear that k[x^2,x^3]=R is a k-algebra with 2 generators and thus there is an induced map from k[t,u] onto R. The kernel most certainly includes this prime ideal (t^2-u^3) and since k[t,u] is dim 2 it is either this prime or a maximal ideal that is the kernel (bc R is a domain) but R isn't a field so the isomorphism follows.
it seems that dimension theory a powerful tool! i am aware of the theorem that k[x_1,..,x_n] has dimension n over a field k though I have never seen a proof! I will investigate further. Another question is this, if a ring, polynomial ring in n variables or otherwise, has dimension n does every prime appear in a chain of length n? Obviously that t^2-u^3 does is clear since (t,u) is maximal and contains it but is it true in general?
Dimension theory (krull dimension anyways) is very much a fundamental part of algebraic geometry, and that's where I first learned it.
Polynomial rings (finite number of variables) over a field are very "homogeneous", so every maximal tower of ideals has the same length. This will then hold true for every finitely generated algebra over a field, just by pulling back to the polynomial ring (as in my very brief previous comment). It's been a really long time since I studied this stuff, so I don't know to what degree this holds for algebras that are not finitely generated. Maybe there are towers of ideals of different lengths in some strange algebra?
It's a great reference book, and pretty cheap, so you may want to look into the book Commutative Algebra: with a View Toward Algebraic Geometry by David Eisenbud. You can't really use it as a textbook, commutative algebra isn't really that kind of subject, but you can learn a ton.
  • · Replies 25 ·
  • · Replies 21 ·
