How can charged particles be deflected by both magnetic and electric fields?
This discussion focuses on the calculations required to determine the values of magnetic field (B_z) and electric field (E_x) necessary to deflect charged particles, specifically electrons and alpha particles, in a circular path. For an electron traveling at 6X10^5 m/s, the required B_z for a radius of 3 cm is calculated to be 1.14E-4 T, while for an alpha particle, it is 0.415 T. The electric field E_x needed for the same electron to be deflected to the right is determined to be 300 N/C. The discussion highlights confusion regarding the interpretation of the problem statements, particularly for parts 3 and 5.
  • Understanding of charged particle motion in magnetic and electric fields
  • Familiarity with the equations r = mv/QB_z and E_x = vB
  • Knowledge of basic physics concepts related to force and acceleration
  • Ability to interpret and analyze physics problem statements
  • Study the derivation of the Lorentz force law for charged particles
  • Learn about the principles of circular motion in magnetic fields
  • Explore the effects of electric fields on charged particle trajectories
  • Investigate graphical representations of charged particle motion in fields
Students studying electromagnetism, physics educators, and anyone involved in solving problems related to charged particle dynamics in electric and magnetic fields.
lwelch70
1) Calculate the value of B_z needed for an electron with a speed of 6X10^5 m/s to be deflected to the right in acirle of radius 3cm.
2) Calculate the value of E_x needed for an alpha particle with a speed of 6X10^5 m/s to be deflected to the right in a circle of radius 3cm.
3) Calculate the value of E_x needed for an electron with a speed of 6X10^5 m/s to be deflected to the right by 3 cm.
4) Calculate the value of E_x needed for any particle with a speed of 6X10^5m/s to be deflected in a magnetic field of .0005T.
5) Calculate the radius of the circle in this helix.
r= mv/QBz
Ex = vB
So problems 1 and 2 are straight forward plug and play. Got those answers to be 1.14E-4 T and .415 T respectively. Problem 4 is also plug and play to come out to 300 N/C.
Where I get out of what is on problem 3 and 5. Any help/equations to get me started? I hate to look like I haven't tried to solve there I just don't know where to go with these. Just need some help along the yellow brick road.
Anyone have any ideas?
It doesn't make sense.
Apart from the peculiar mix of Cartesian directions and left/right, I assume the x direction to mean the original direction of travel.
In which case for part 3 the field E_x would be along that same direction and would merely impart additional acceleration. To the right?! - it's meaningless.
I don't see how you answer 4 so confidently either. It just says 'to be deflected' How much? are we to assume it's the same 3cm radius?
The first two parts are reasonable and fairly trivial questions - but the rest of it is garbage.
Is there a diagram? Is that what's missing?
  • · Replies 27 ·
