Hensel's lemma (Understanding it's Proof)
  • Context: Graduate
  • Thread starter Thread starter sidm
    Proof
This discussion focuses on Hensel's lemma, particularly its proof involving monic polynomials in a discrete valuation ring A and their behavior under a normalized nonarchimedean valuation. The lemma states that if a monic polynomial f in A[x] factors into g'h' in the residue field k[x], then there exist monic polynomials g and h in A[x] that also factor f while maintaining congruence with g' and h' modulo the maximal ideal m. The proof involves constructing polynomials inductively and ensuring that the degrees of certain polynomials u and v are controlled to maintain the monicity and degree of the iterants.
  • Understanding of discrete valuation rings and their properties
  • Familiarity with nonarchimedean valuations and their applications
  • Knowledge of polynomial factorization in the context of algebraic structures
  • Concept of Cauchy sequences and convergence in the context of polynomials
  • Study the implications of Hensel's lemma in algebraic number theory
  • Explore the construction of Cauchy sequences in the context of polynomial convergence
  • Learn about the properties of monic polynomials in discrete valuation rings
  • Investigate the relationship between polynomial degrees and their congruences in valuation theory
Mathematicians, particularly those specializing in algebraic number theory, graduate students studying valuation theory, and researchers interested in polynomial factorization methods.
sidm
We're are looking at a field, K, complete with respect to a (normalized nonarchimedean) valuation, ||, and let A be it's discrete valuation ring (all elements of K with absolute value less than or equal to 1) with maximal ideal m=(p), it's residue field k=A/m...now Hensel's lemma can be stated as follows: Let f be monic in A[x] and f' its image in k[x], if f'=g'h' in k[x] with g',h' monic and relatively prime in k[x] then there are g,h in A[x] both monic such that f=gh and g and h are relatively prime with g and h congruent to g' and h' respectively modulo m.
First off let me see if i got this straight: Say we're looking at Zp (completion of integers w.r.t. p) then to factor a monic polynomial in Zp[x] we only need to factor it over Zp/(p)[x] (which is isomorphic to F_p[x]!) ?
Now the proof is long winded but I will sketch it, it involves showing first that if the g' and h' are relatively prime over the residue field then g and h are in A[x] with u and v in A[x] with degrees less than g and h respectively s.t. gv+hu=1. Then we prove that if such a pair exists then it's unique. Now the last part is what I'm having trouble with, existence:
They construct the polynomials inductively at each step producing a g_n,h_n such that g_n is congruent to g_0 modulo m and similarly for h_n & h_o also that f=h_ng_n modulo m^{n+1}. The base case is obviously what we've been given as a hypothesis so then they proceed to build the next polynomials, they say they need a u and v with degu<deg(g_0), degv(v)<deg(h_0) such that f=(h_n+p^{n+1}v)(g_n+p^{n+1}u) modulo p^{n+2}. Note here p is the generator for m.
This is where I'm confused and also where the proof ends, why do the degrees of the polynomials of u and v have to be controlled?
So say we have all our h_n's and g_n's then we would take their limit (i.e the limits of the coefficients) which are well defined because the sequence defined by say the coefficient of x^i in the h_n's are cauchy:
say (m>n)
|h_n-h_m| is no bigger than |p^{n+1}| and the absolute value consists precisely of the sum of the differences of coefficients. But how do we actually know that each of these differences is small? It's clear that the total sum of these differences goes to zero but i don't know of a way to talk about the convergence of polynomials other than coefficient-wise.
Any help would be appreciated.
well i have an answer tomy last question: h_n-h_m=p^{n+1}(something) thus the difference between coefficients of say x_i is a multiple of p^{n+1} is thus small. Thus h and g exist and clearly their product is equal to f:
f-gh has arbitrarily small absolute value (triangle inequality with h_ng_n for large enough n) so must be zero.
Still I'm not absolutely certain as to why the degrees of u and v above have to be controlled: maybe this is to maintain the monicity and degree of each iterant of the polynomial?
That sounds reasonable.
You know that g and h are monic, and you know their degrees. Modulo pk, gn couldn't possibly be congruent to g if gn wasn't also monic and of the same degree.
Sure, you could find a different Cauchy sequence that converges to g, but why?
  • · Replies 26 ·
  • · Replies 28 ·
