Continuity and Polar Coordinates
The discussion revolves around the continuity of the function f(x,y) = xy/sqrt(x^2+y^2) at the origin, specifically using polar coordinates for the analysis. The function is defined to be zero at the origin (0,0).
  • Exploratory, Assumption checking
  • Participants discuss converting the function into polar coordinates and the implications of the polar representation for continuity at the origin. Questions arise regarding the definition of θ at the origin and the relevance of θ in determining limits as r approaches zero.
The conversation is ongoing, with participants exploring different perspectives on the use of polar coordinates and the behavior of the function as it approaches the origin. Some guidance has been offered regarding the independence of the limit from θ, while alternative approaches have also been suggested.
There is a mention of the limitations of Cartesian coordinates in assessing continuity compared to polar coordinates, as well as the potential for different limits along various paths in Cartesian space.
schmidt7100
Show that the function f(x,y)= xy/sqrt(x^2+y^2) is continuous at the origin using polar coordinates. f(x,y)=0 if (x,y)=(0,0)
r=sqrt(x^2+y^2)
x=rcos(theta)
y=rsin(theta)
So, converting this equation to polar coordinates, I get rsin(theta)cos(theta). However, after this I'm stumped as to how I prove that this is continuous at the origin.
At the origin in polar coordinates (r,θ), shouldn't r=0 and θ=0 ?
Not exactly- at the origin r= 0 and [itex]\theta[/itex] is undefined.
However, Schmidt7100, the point is that r alone measures the distance of a point from the origin- [itex]\theta[/itex] is irrelevant. That means that, if [itex]\lim_{r\to 0}f(r,\theta)[/itex] does not depend on [itex]\theta[/itex], then that is the limit of [itex]f(r, \theta)[/itex] as [itex](r, \theta)[/itex] goes to the origin.
Note that is NOT the case for Cartesian coordinates. Since the distance from (x, y) to (0, 0) depends upon both x and y. I am sure you have seen examples of functions in (x, y) that give different limits as you go to (0, 0) along different paths.
You don't have to use polar co-ordinates, let
[tex] x_{n}=\frac{1}{n},\quad y_{n}=\frac{1}{n}[/tex]
Insert these into your equation for f and let [tex]n\rightarrow\infty[/tex], compute the limit and if it's the same as f(0,0) you've proved continuity.
  • · Replies 20 ·
  • · Replies 19 ·
