Beginner's Question Regarding Voltage Division
  • Thread starter Thread starter Ulnarian
    Division Voltage
The discussion revolves around the concept of voltage division in electrical circuits, particularly focusing on a beginner's understanding of how voltage is distributed across resistors in a circuit. Participants explore calculations related to voltage drops and the implications of measuring voltage between different points in the circuit.
  • Homework-related
  • A participant presents a circuit diagram and attempts to calculate the voltage between various points using Ohm's law, concluding that the current is 1A and calculating voltage drops across resistors.
  • Some participants confirm the calculations and assert that voltage drops occur across resistances, suggesting that voltage increases with resistance in the context of a series circuit.
  • There is a discussion about the measurement of voltage, emphasizing that voltage is a potential difference between two points, and questioning how to accurately measure voltage at point 6 in relation to other points.
  • One participant cautions that voltage dividers are not suitable for powering devices from higher voltage supplies, indicating a common misconception among beginners.
  • A link to an interactive voltage divider tool is provided for further exploration of the concept.
Participants generally agree on the basic principles of voltage division and the calculations presented, but there is some uncertainty regarding the implications of measuring voltage at different points in the circuit and the practical applications of voltage dividers.
There are limitations in the discussion regarding the assumptions made about the circuit configuration and the definition of ground in the context of voltage measurements. The practical application of voltage dividers as power supplies is also noted as a potential misunderstanding.
Ulnarian
I'm pretty much a beginner trying to wrap my head around the concept of voltage division within a circuit. To help myself out, I've come up with the following circuit.
[PLAIN]http://img401.imageshack.us/img401/801/voltagedivision.gif
I am having trouble determining the voltage between various points on the circuit.
Starting with Ohms law, I know that the current in the circuit is 15V/15 ohms (or, 1A).
Given the current, I can now determine the voltage between various points of the circuit.
Between points 1 and 2, the amount of voltage is:
V=1A x 5 ohms=5V
Between points 1 and 3, the amount of voltage is:
V=1A x (5 ohms + 5 ohms)
V=1A x 10 ohms=10V
Is this correct? Does the amount of voltage actually increase as your resistance increase? Sorry for sounding like a complete noob (which I am :) )
Additionally, say I need to supply 10V to a device that happens to be connected at point 6 on my drawing. Where is the voltage measured from? Assuming I'm correct, if you measure from point 1 to point 6, then there is 10V being supplied. However, if you measure from point 2 to point 6, there is only 5V being supplied. Which figure is accurate?
Your calculations seem correct.
Current passing through a resistance make the voltage drop.
For your last questions, I don't believe I follow you very well. Electric potential is always applied / measured between two points of a circuit. Therefore, it would be difficult to add 10V at point 6.
Cheers
Ulnarian said:
Is this correct?
In short... yes :)
The basic answer is... yes :)
Remember that voltage is always really a potential difference between two points; it's not absolutely defined at one point in a circuit.
What is the ground point in your circuit? Your device that you're connecting must have a ground, or "another side" to the circuit, where the current flows back out.
Also... remember that in practice voltage dividers aren't useful as power supply voltage regulators to power devices from a higher voltage supply than is appropriate... this is a common beginner mistake.
Here's a little interactive voltage divider you might like to play with.
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/voldiv.html"
  • · Replies 19 ·
  • · Replies 19 ·
