Thread Closed
Ohm's Law Application Problem
Share Thread Thread Tools
Jul31-10, 11:02 PM   #1
1. A car, 5 km distance from a station, take 100 A over a 100 mm hard drawn copper trolley wire having a resistance of 0.270 ohm per km. The rail and ground return has a resistance of 0.06 ohm per km. If the station voltage is 750 V, what is the voltage of the car?
2. Relevant equations
I think this are the relevant equations..
I assume that they are connected in series..
so I[sub]car=I[sub]rail
V[sub]t=V[t]station
i don't know what to do with 0.0270 and 0.06 ohms per km..
3. The attempt at a solution
I tried solving for V[sub]car by V[sub]car=I[car]*R[car]
where in I[sub]car=100 A and R[sub]car is 0.0270 ohm/km(1km/1x10^6mm)(100mm)
V[sub]car=2.7x10^-4.. which is obviously wrong because V[station]=750V and its impossible that the car only takes 2.7x10^-4 V.. Pls help me thanks.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Jul31-10, 11:16 PM   #2
Mentor
You are given all the information you need to compute the total resistance of the wire and the rail. Once you have the resistance it is easy to compute the voltage drop of the wire and rail. You can then find the voltage at the car.
Aug1-10, 01:09 AM   #3
Are the wire and rail in series or in parallel with the car?? What must I do with the voltage of the station??
Thread Closed
Thread Tools
Similar Threads for: Ohm's Law Application Problem
Thread Forum Replies
The Law of Conservation Problem! (Application) Introductory Physics Homework 3
Simple Circuit Diagram (Ohm's Law Application) Introductory Physics Homework 14
Resistance and Ohm's Law Problem Introductory Physics Homework 4
Mechanics application problem Introductory Physics Homework 1
Application of Differentiation Problem Calculus 2
