Parallel vs anti parallel electron spin
The discussion revolves around the configuration of electron and proton spins in a hydrogen atom, specifically whether parallel or anti-parallel spins represent a lower energy state. The context is set within a general physics framework, touching on concepts of spin and magnetic interactions.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants explore the implications of spin configurations, with one suggesting that anti-parallel spins may be the lower energy state but expressing uncertainty about the reasoning. Others introduce concepts like hyperfine interaction and magnetic dipole energy without providing detailed calculations.
The discussion is active, with participants offering guidance on relevant concepts and suggesting areas for further exploration, such as the hyperfine interaction and the role of quantum mechanics. There is no explicit consensus on the correct configuration, but various lines of reasoning are being examined.
Participants note that the topic may be challenging given its assignment in a general physics class, indicating potential gaps in prior knowledge related to quantum mechanics and spin interactions.
dogeatdog
a hydrogen atom with its electron in the ground state 1s orbital can have proton and electron spins that are either parallel or anti parallel. which is the lower configuration and why? treat the electron as orbiting the proton in a plane perpendicular to the spin of the proton.
the Heitler London model may have something to do with it but I am not sure.
i also know that the splitting of spectral lines is due to the property of spin
im pretty sure the answer is anti parallel but i have no idea why. this was assigned for a general physics class which i think is crazy since we never even talked about anything like this. Please Help or steer me in the right direction or something. thanks
I suggest you look up the hyperfine interaction. Hydrogen is a famous case leading to the 21 cm hydrogen line used in radio astronomy.
Without calculations, I would answer based on opposite poles of magnets attracting. For a bit more detail, use the energy of a magnetic dipole in a B field.
The classical solution of magnetic field and dipoles is incorrect in this case. It turns out you have to use quantum mechanics to get the right solution for this problem.
