How Do You Calculate River Flow Velocity in a Kinematics Problem?
The discussion focuses on calculating the flow velocity of a river in a kinematics problem involving a motorboat and a raft. The motorboat travels downstream, overtakes the raft, and then returns to meet the raft again 6 km downstream after 60 minutes. The key equations established are based on the velocities of the stream (v0) and the motorboat (v'), leading to the relationship d = vt0 = v0t + (v - v0)t, where L = v0(t + t0). The flow velocity can be derived from these equations.
  • Understanding of kinematics principles
  • Familiarity with velocity and time equations
  • Basic algebra for solving equations
  • Knowledge of relative motion concepts
  • Study the concept of relative velocity in fluid dynamics
  • Learn how to apply kinematic equations in real-world scenarios
  • Explore the derivation of flow velocity in river problems
  • Investigate the effects of constant engine duty on boat speed
Students studying physics, particularly those focusing on kinematics and fluid dynamics, as well as educators looking for practical examples of velocity calculations in river flow scenarios.
LHC_23
A motorboat going downstream overcame a raft at a point A;
• = 60 min later it turned back and after some time passed the raft
at a distance l = 6.0 km from the point A. Find the flow velocity
assuming the duty of the engine to be constant.
I assumed the stream velocity as v0 and the velocity of the motorboat with respect to water as v' . The motorboat reached point B while going downstream with velocity (v0 + v') and then returned with velocity (v' - v0) and passed the raft at point C . Then I assumed t to be the time for the raft to move from point A to C , during which the motorboatboat moves from A to B and then from B to C .
But after this I have no idea how to proceed .
Pls Help!
Let [tex]v_{0}[/tex] be the velocity of the stream, [tex]v[/tex] velocity of the motorboat, [tex]t_{0}[/tex] time after the motorboat changes direction (60 minutes) and [tex]L[/tex] distance form point A (6 km).
After 60 minutes, distance between boats is
[tex]d=vt_{0}.[/tex]
At that moment, motorboat is at point B. After time [tex]t[/tex] passes, the boats meet at point C. So, they travel their own distances in the same time interval [tex]t[/tex]. Therefore
[tex]d=vt_{0}=v_{0}t+(v-v_{0})t.[/tex]
And we also know
[tex]L=v_{0}(t+t_{0}).[/tex]
[tex]v_{0}[/tex] is easy to obtain from those equations.
Pls Help!
But the motorboat is only an observer, otherwise irrelevant. The raft traveled 6 km in 60 minutes.
  • · Replies 34 ·
