KG and SEC as the basis of all units?
by Curl
Tags: basis, units
Curl
Curl is offline
#1
Aug5-10, 06:40 PM
P: 751
About 6 minutes ago I thought of this, and I want to check if it is true.
Is the kilogram and the second a basis for all units in existence?
That is, can all units be derived from these two? I can't think of any other units that are independent.
Phys.Org News Partner Physics news on Phys.org
Physicists design quantum switches which can be activated by single photons
'Dressed' laser aimed at clouds may be key to inducing rain, lightning
Higher-order nonlinear optical processes observed using the SACLA X-ray free-electron laser
rock.freak667
rock.freak667 is offline
#2
Aug5-10, 06:44 PM
HW Helper
P: 6,213
mass kg
length m
time s
current A
substance mol
intensity of light cd
Temperature K
fundamental quatities
You use these base units to derive all others.
Curl
Curl is offline
#3
Aug5-10, 09:12 PM
P: 751
length - not needed since the meter is defined as the distance traveled by light in X amount of time.
current - based of coulombs and seconds. Not a fundamental unit.
substance - included in KG. Mol is just a number, not a unit.
intensity of light - energy density, energy is derived from kg*(m/s)^2 and meter is derived as stated above.
temperature - in an ideal gas it is derived from the RMS speed of the gas molecules, in m/s; meters derived as above, seconds fundamental. For solids temperature is defined as T1=T2 if heat=zero when two bodies are in thermal contact (one body is the ideal gas).
then there are others:
magnetic field - derived from kg and sec, since the volume integral of the magnetic field is directly proportional to energy, and energy again is derived from kg and sec.
electric field - derived from magnetic field by maxwell's equations or from the coulomb.
coulomb - since charge is fundamental, it can be directly related to the kilogram (1kg of charged particles = x coulombs) or it can be derived from the electric field/magnetic field/ speed of light
I can't think of any other units that can be questionable.
diazona
diazona is offline
#4
Aug5-10, 10:46 PM
HW Helper
P: 2,156
Quote Quote by Curl View Post
It kind of depends on what you consider to be a derivation.
It sounds like you're taking the view that, if you can multiply a unit of X by some combination of fundamental physical constants to get a unit of Y, then Y is a derived quantity. For example, multiplying the second (a unit of time) by the speed of light (a fundamental constant) gives you the light-second (a unit of length), thus length is a derived quantity. With that view, then yes, the kilogram and second will allow you to derive all other units.
But you can go further than that - you don't need any base units at all. The fundamental constants automatically suggest a particular set of base units, called the Planck units. They're awfully tiny quantities, though, so they're really inconvenient to use for anything except high-energy theoretical work (string theory and the like). That's why we define things like the kilogram, meter, second, etc., so that we have a set of units that corresponds more closely to the quantities we encounter in everyday life.
rcgldr
rcgldr is offline
#5
Aug6-10, 01:22 AM
HW Helper
P: 6,925
Possible alternative from wiki article:
A coulomb is then equal to exactly 6.24150962915265 1018 positive elementary charges. Combined with the present definition of the ampere, this proposed definition would make the kilogram a derived unit.
http://en.wikipedia.org/wiki/Coulomb#Explanation
Curl
Curl is offline
#6
Aug6-10, 01:27 AM
P: 751
yes but the "elementary charges" can have different masses (mass of proton is not equal to mass of electron). Also there is high uncertainty in the mass (in kg) of a proton/electron which still makes it a bit difficult to make the kilogram a derived unit.
Personally I don't like the idea of having a block in Paris and saying "this is 1.0000000000000000... kg". Why can't we just define it "mass of X number of hydrogen atoms"?
diazona
diazona is offline
#7
Aug6-10, 02:05 AM
HW Helper
P: 2,156
There's exactly the same uncertainty in the value of Avogadro's number, but that doesn't stop us from using it to define the mole as a derived unit.
You try counting out 1027 hydrogen atoms without losing track of a few trillion along the way People actually are trying to do this, though: there's a project to create a new standard definition of the kilogram, as the mass of some integer number of carbon atoms. The exact number will have to be decided on before they finish, because we don't know exactly how many carbon atoms would equal the mass of the current standard kilogram.
jhmar
jhmar is offline
#8
Aug6-10, 03:16 AM
P: 76
Quote Quote by diazona View Post
............ because we don't know exactly how many carbon atoms would equal the mass of the current standard kilogram.
Mass is a fixed quantity, weight (kilogram) is determined by gravitational force; hence the number of carbon atoms that = 1K depends on the G force. The true fundamentals are internal force (energy) and external force (force).
N carbon atoms weigh 1K when subject to X gravitational force.
Hypersphere
Hypersphere is offline
#9
Aug6-10, 06:10 AM
P: 178
The choice of the units you consider fundamental should depend on the practical accuracies as well. Well, at least if you want to use them for measuring things and deriving other units. Post #53 in http://www.physicsforums.com/showthr...=418112&page=4 has a bit on this when it comes to the kilogram. Likewise the SI system takes the current over the charge, since it's easier to measure accurately.
rcgldr
rcgldr is offline
#10
Aug6-10, 02:34 PM
HW Helper
P: 6,925
Quote Quote by rcgldr View Post
The mass of the protons and/or electrons wouldn't be a part of the derivation of kg. Instead it would be based on the force between 2 wires carrying 1 amp of current and a rate of acceleration.
1 A = the constant current which will produce an attractive force of 2 10–7 newtons per metre of length between two straight, parallel conductors of infinite length
http://en.wikipedia.org/wiki/Ampere
Ampere would be derived from the definition of coulomb and second.
1 A = 1 coulomb / second
1 second = the duration of 9,192,631,770 periods of the radiation corresponding to the transition between the two hyperfine levels of the ground state of the caesium 133 atom.
http://en.wikipedia.org/wiki/Second
So 1 newton would be a force derived based on the derived value of 1 amp.
Then 1 kg would be the amount of mass accelerated at 1 m / s2 by a force of 1 newton.
1 kg = 1 N s2 / m
1 meter = the length of the path travelled by light in vacuum during a time interval of 1 ⁄ 299792458 of a second
http://en.wikipedia.org/wiki/Metre
diazona
diazona is offline
#11
Aug6-10, 05:15 PM
HW Helper
P: 2,156
Quote Quote by jhmar View Post
No, the kilogram is a unit of mass, abbreviated kg. The concept of weight doesn't enter into my argument at all.
Studiot
Studiot is offline
#12
Aug6-10, 05:41 PM
P: 5,462
light??
what sort of light??
rcgldr
rcgldr is offline
#13
Aug6-10, 07:27 PM
HW Helper
P: 6,925
Quote Quote by Studiot View Post
light?? what sort of light??
All light in a vacuum travels at the same speed.
Studiot
Studiot is offline
#14
Aug7-10, 03:20 AM
P: 5,462
Can you prove that?
Or is it an additional axiom?
diazona
diazona is offline
#15
Aug7-10, 12:18 PM
HW Helper
P: 2,156
Can you prove that?
There have been many experimental observations which support that conclusion. For instance, pulses of different kinds of EM radiation coming from distant stars and galaxies arrive at Earth-based telescopes in perfect synchronization.
Studiot
Studiot is offline
#16
Aug7-10, 12:35 PM
P: 5,462
Yes I am not disputing that, I am just observing that if you want to claim something as fundamental and underlying other things then the basis has to be stronger than just support for a theory.
For instance is there any proof for EM wavelengths equal to or greater than the the measurement distance? To be fundamental it would have to work for all possible wavelengths including unusual ones.
Curl
Curl is offline
#17
Aug7-10, 08:17 PM
P: 751
It works through Maxwell's equations, I don't know if you have studied that.
If Maxwell's equations aren't correct, then we're not in the position to derive any units until it has been figured out.
rock.freak667
#18
Aug7-10, 08:20 PM
HW Helper
P: 6,213
How then do you measure the the distance then without a unit of length?
If I remember the definition properly, a mole relates the amount of a substance to C-12.
But it seems that the second is further defined as a certain number oscillations and so on.
As far as basic physics for engineering is concerned, those fundamental quantities are fine. Perhaps if you are studying atoms and quantum physics, they may not be.
Register to reply
Related Discussions
Converting units in scientific notation to other units. Precalculus Mathematics Homework 5
matrix connecting Sz diagonal basis to Sx diag basis Quantum Physics 0
Basis independent and basis dependent formulation of QM Advanced Physics Homework 0
FAQ:What's the differences between Radiometric Units and Photometric Units? Introductory Physics Homework 2
Maxwell related equations converted from MKSA units to Gaussian units Classical Physics 2
