What is the Optimal Wire Spacing for a Strong Magnetic Field in a Solenoid?
The discussion revolves around calculating the magnetic field strength inside a solenoid using a specific length of copper wire and a given current. The problem involves determining the number of turns per unit length (n) for the solenoid based on the wire's dimensions and constraints.
  • Conceptual clarification, Problem interpretation, Assumption checking
  • Participants explore how to calculate the number of turns per unit length (n) and question the limitations affecting this calculation. There is discussion about the relationship between the wire length, solenoid dimensions, and the packing of turns.
Some participants have provided insights into the definition of n and its implications for the solenoid's construction. There is an ongoing exploration of how to accurately determine n, with various interpretations being discussed. Guidance has been offered regarding the relationship between wire length and the turns per unit length.
Participants are working within the constraints of the problem, including the specific dimensions of the wire and solenoid, as well as the limitations imposed by the available wire length and current capacity.
pat666
You have 12m of 0.50mm diameter copper wire and a power supply capable of passing 17A through the wire.
What magnetic field strength would you obtain inside a 2.0-mm-diameter solenoid with the wire spaced as closely as possible?
My problem is that I can't find n - tried about 50 times but its always wrong.
n=12/(pi*0.0205) wrong
n=12/(pi*0.02) wrong
n=0.02pi wrong never thought this was right but I can't think of anything else to do? for a mastering physics online question so no answer yet.
I thought the only limitations were the length of the wire and the radius/diametre of the solenoid?
yeah n is turns/length
The turns per unit length tells you how closely you can pack the loops next to each other. The overall length of the wire and the size of the solenoid really have nothing to do with that.
really, so how do I find out n then?
hey, so n will be .0005/something
Almost! You have 0.0005 m per turn, so you have 1 turn per 0.0005 m, which is 2000 turns/m.
Thanks vela! that problem had me screwed.
10K
  • · Replies 21 ·
