| Thread Closed |
inertial reference frames |
Share Thread |
| Aug11-10, 05:21 PM | #1 |
An example of an inertial reference frame is: A. any reference frame that is not accelerating B. a frame attached to a particle on which there are no forces C. any reference frame that is at rest D. a reference frame attached to the center of the universe E. a reference frame attached to Earth 2. Relevant equations 3. The attempt at a solution This isn't really a homework problem because the answer is given to me as B. I guess that makes sense. If there are no forces on an object, then it will move with constant velocity and thus, must be an inertial reference frame. But I'm not clear as to why the answer can't be A or C. Is it because the idea of a frame of reference is relative and the ideas of "at rest" and "not accelerating" aren't defined within a given frame of reference? I think I'm confused on this whole idea of inertial reference frames. If anyone has some insight that can help me, that would be great. Thanks a lot. 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution |
| Aug11-10, 06:59 PM | #2 |
Recognitions:
Honestly, I think this is a badly written question, and it's more likely to just confuse you than to test your understanding of anything. For future reference, by the way, the standard definition of an inertial reference frame is one in which the law of inertia applies: an object subject to no external forces moves with a constant velocity. As far as anyone knows, this is equivalent to saying that an inertial reference frame is one in which Newton's second law (ΣF=ma) holds. |
| Aug11-10, 07:44 PM | #3 |
Hey thanks a lot for the quick response. I appreciate it.
| Thread Closed |
| Tags |
| inertial, reference frames |
Similar Threads for: inertial reference frames
| inertial frames of reference | Introductory Physics Homework | 0 | ||
| Inertial and Non-Inertial Frames of Reference Question | Introductory Physics Homework | 6 | ||
| Frames of reference & Inertial frames | Classical Physics | 2 | ||
| inertial reference frames | General Physics | 2 | ||
| inertial reference frames | Special & General Relativity | 2 | ||
