Thread Closed
Linear Momentum/Impulse Problem
Share Thread Thread Tools
Aug15-10, 10:47 AM   #1
A ball with a mass of .2 kg travelling at a speed of 26 m/s is struck by a bat. If the duration of the impulse is .001 seconds and the speed of the ball afterwards is the same as before, what is the average force (to the nearest Newton) of the impact? On the other hand, if the magnitude of the average force is 20000 N, what is the speed to the nearest m/s after collision?
2. Relevant equations
Fnett =[tex]\Delta[/tex]p = m[tex]\Delta[/tex]v
3. The attempt at a solution
F=(.2 kg)(26m/s-0)/.001 = 5200
This answer is always 1/2 off the correct answer so I'm not sure if the equation I'm using is wrong or if I'm applying it incorrectly. As for the second question, I'm not quite sure where to go with it.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Aug15-10, 11:49 AM   #2
Haha I got the answer. It goes back to thinking Kinematics equations where vf=vi+at
therefore, to get the acceleration you use Newton's second law: F=ma where F= 20000N and m = .2 to get a = 100,000
vf = vi + at
vf= 26 - (100,000)(.001)
vf = -74 m/s
vf is 74 m/s in the opposite direction it was thrown in
hope this helps someone else that's stuck
Thread Closed
Thread Tools
Similar Threads for: Linear Momentum/Impulse Problem
Thread Forum Replies
Impulse, Linear momentum...belly flop Introductory Physics Homework 1
[SOLVED] Linear momentum and impulse problem Introductory Physics Homework 4
Linear Impulse/Momentum Introductory Physics Homework 2
linear impulse and linear momentum Introductory Physics Homework 5
Collision and Impulse, Linear Momentum Introductory Physics Homework 16
