| Thread Closed |
On the radius of convergence of a power series |
Share Thread | Thread Tools |
| Aug16-10, 08:42 AM | #1 |
Hi, I'm new here. I am curious that why a power series must have a radius of convergence? I mean, even in a complex plane, there is always a so-called convergent radius for a power series. Is it possible that a power series is convergent for a certain range in one direction, and for an apparent shorter/longer range in some other direction? So far all the text books I read do not give lessons over this question. Any answer or hint or instruction will be much appreciated.
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Aug16-10, 09:14 PM | #2 |
The answer is no, it can't have a larger range of convergence in a different direction. The relevant theorem is the Cauchy-Hadamard theorem. Lots of links on the internet, one of which is:
http://eom.springer.de/c/c020870.htm |
| Aug17-10, 02:44 AM | #3 |
This is a really great question, though. Its answer is part of the beauty of complex analysis.
| Aug17-10, 07:22 AM | #4 |
It is, basically, an application of the "ratio test".
If [itex]f(z)= \sum a_n(z- z_0)^n[/itex]] then the series converges, absolutely, as long as [tex]\lim_{n\to\infty}\frac{|a_{n+1}(z- z_0)^{n+1}|}{|a_n (z- z_0)^n|}[/tex][tex]= |z- z_0|\lim_{n\to\infty}\frac{a_{n+1}{a_n}|< 1[/tex] and diverges if that limit is larger than 1. As long as [tex]\lim_{n\to\infty}\frac{a_{n+1}}{a_n}= A[/tex] exists, then we have that the power series converges for [tex]|z- z_0|< \frac{1}{A}[/tex] and diverges for [tex]|z- z_0|> \frac{1}{A}[/tex] You can get the same result by using the root test instead of the ratio test: [itex]\sum a_n (z- z_0)^n[/itex] converges absolutely as long as [tex]\lim_{n\to\infty}\left(a_n(z- z_0)^n)^{1/n}= \left(\lim_{n\to\infty}\sqrt[n]{a_n}\right)|z- z_0|[/tex] is less than 1. |
| Aug17-10, 07:41 AM | #5 |
thank you all for the replies. That does help.
| Aug17-10, 11:00 AM | #6 |
OK, I think I get it. Thank you.
| Thread Closed |
| Tags |
| convergence, power series, radius |
| Thread Tools | |
Similar Threads for: On the radius of convergence of a power series
| Power Series- radius of convergence | Calculus & Beyond Homework | 2 | ||
| Radius of convergence of a power series | Calculus & Beyond Homework | 5 | ||
| Finding Radius of Convergence of the Power Series | Calculus & Beyond Homework | 1 | ||
| Radius of convergence of power series | Calculus & Beyond Homework | 2 | ||
| Power series and finding radius of convergence... | Calculus & Beyond Homework | 2 | ||
