Local lorentz tranformations of fermion action
  • Context: Graduate
  • Thread starter Thread starter jdstokes
    Fermion Local Lorentz
The discussion focuses on the local Lorentz transformations of the fermion action in curved spacetime, specifically analyzing the transformation of the derivative operator \(D_\mu \psi\). The action is defined as \(S = -\int d^4 x \sqrt{- \det(\eta^{ab} e_{a\mu}e_{b\nu})} \left[ i\overline{\psi} e^\mu_a \gamma^a D_\mu \psi + i m \overline{\psi}\psi \right]\). The transformation rules for \(\psi(x)\), \(e_{a\mu}(x)\), and \(\omega_{ab\mu}(x)\) are derived, leading to a covariant form of \(D_\mu \psi\). The author identifies a potential error in their calculations regarding the transformation of \({\omega^a}_{b}\) instead of \(\omega_{ab}\), which may resolve the issue with the last term in the expression for \(D_\mu' \psi'\).
  • Understanding of fermionic actions in quantum field theory
  • Familiarity with curved spacetime and general relativity concepts
  • Knowledge of local Lorentz transformations and their implications
  • Proficiency in manipulating Dirac matrices and spinors
  • Study the transformation properties of spinors under local Lorentz transformations
  • Explore the derivation and implications of the covariant derivative in curved spacetime
  • Investigate the role of the spin connection \(\omega_{ab\mu}\) in fermionic actions
  • Learn about the anti-symmetry properties of the transformation parameters \(\theta_{ab}\)
The discussion is beneficial for theoretical physicists, particularly those specializing in quantum field theory, general relativity, and the study of fermionic fields in curved spacetime.
jdstokes
The action for a fermion in curved spacetime is
[itex]S = -\int d^4 x \sqrt{- \det(\eta^{ab} e_{a\mu}e_{b\nu})} \left[ i\overline{\psi} e^\mu_a \gamma^a D_\mu \psi + i m \overline{\psi}\psi \right][/itex]
where [itex]g_{\mu\nu} = \eta^{ab} e_{a\mu} e_{b\nu}[/itex] and the derivative operator acting on fermions is given by
[itex]D_\mu \psi = \partial_\mu \psi - \frac{i}{2} \omega_{ab\mu} S^{ab} \psi[/itex]
where [itex]S^{ab} = -(i/4)[\gamma^a,\gamma^b][/itex].
I am failing to show that [itex]D_\mu \psi[/itex] transforms covariantly under local Lorentz transformations.
As far as I understand, the relation [itex]\omega_{ab\mu} = e_a^\nu \nabla_\mu e_{b\nu}[/itex] implies that the following transformation rules
[itex]\psi(x) \mapsto \Lambda_{1/2}(x) \psi(x)[/itex]
[itex]e_{a\mu}(x) \mapsto {\Lambda^a}_b(x) e_{b\mu}(x)[/itex]
[itex]\omega_{ab\mu}(x) \mapsto {\Lambda^{\alpha}}_a(x) \omega_{\alpha\beta\mu}(x) {\Lambda^\beta}_b(x) + \eta_{\alpha\beta}{\Lambda^\alpha}_a(x)\partial_\mu {\Lambda^\beta}_b(x)[/itex].
Plugging these transformations into [itex]D_\mu \psi[/itex] for an infinitesimal Lorentz transformation, for which
[itex]{\Lambda^a}_b = \delta^a_b + \theta^a_b[/itex]
[itex]\Lambda_{1/2} = 1 + (i/2)\theta_{ab} S^{ab}[/itex]
I obtain
[itex]D_\mu \psi \mapsto D_\mu' \psi' = (\partial_\mu \Lambda_{1/2})\psi + \Lambda_{1/2} \partial_\mu \psi - \frac{i}{2}\left[{\Lambda^{\alpha}}_a \omega_{\alpha\beta\mu} {\Lambda^\beta}_b + \eta_{\alpha\beta}{\Lambda^\alpha}_a \partial_\mu {\Lambda^\beta}_b \right]S^{ab}\Lambda_{1/2}\psi[/itex]
In infinitesimal form:
[itex]D_\mu' \psi' = \frac{i}{2} \partial_\mu \theta_{ab} S^{ab}\psi + (1 + i/2\, \theta_{ab}S^{ab})\partial_\mu \psi -\frac{i}{2}\left[(\delta^\alpha_a + \theta^\alpha_a)\omega_{\alpha\beta\mu}(\delta^\beta_b + \theta^\beta_b) + \eta_{\alpha\beta} (\delta^\alpha_a + \theta^\alpha_a ) \partial_\mu \theta^\beta_b \right] S^{ab}(1 + i/2\, \theta_{cd}S^{cd})\psi[/itex]
Ignorning quadratic terms and using the anti-symmetry of [itex]\theta_{ab}[/itex]:
[itex]D_\mu' \psi' = (1 + i/2\, \theta_{ab}S^{ab})\partial_\mu \psi -\frac{i}{2} \left( \omega_{ab\mu} S^{ab} + \frac{i}{2} \omega_{ab\mu} \theta_{cd} S^{ab} S^{cd}\right)\psi - \frac{i}{2}\left( \omega_{a\beta\mu} \theta^\beta_b + \omega_{\alpha b \mu} \theta^\alpha_a\right) S^{ab} \psi[/itex]
The first two terms combine to give [itex](1+ i/2 \, \theta_{cd}S^{cd})(\partial_\mu - i/2\, \omega_{ab\mu}S^{ab})\psi = \Lambda_{1/2} D_\mu \psi[/itex] as required, but the last term does not have anything to cancel with. Does anyone have any suggestions about where I might be going wrong?
I think the error lies in the fact that I should be considering the transformation of [itex]{\omega^a}_{b}[/itex] rather than [itex]\omega_{ab}[/itex]. The transformation rule for [itex]{\omega^a}_{b}[/itex] is
[itex]{\omega^a}_{b\mu}(x) \mapsto {\Lambda^\beta}_b(x) {\omega^\alpha}_{\beta\mu}(x) {\Lambda_{\alpha}}^a(x) + [\partial_\mu {\Lambda^\alpha}_b(x)]{\Lambda_\alpha}^a(x)[/itex]
expanding this into infinitesimal form gives extra minus signs because of [itex]{\Lambda^a}_b = \delta^a_b + \theta^a_b[/itex] and [itex]{\Lambda_a}^b = \delta^b_a - \theta^b_a[/itex]. These cause the last term in the expression for [itex]D_\mu' \psi'[/itex] to cancel.
  • · Replies 16 ·
