Area of Region Under Graph x=-pi/6 to x=pi/4: Find the Solution
  • Thread starter Thread starter tomwilliam
    Area Graph
The discussion revolves around finding the area of the region between x=-π/6 and x=π/4 above the x-axis and below the graph of the function y=cos(2x)(8-cos(2x)). The subject area is calculus, specifically focusing on integration techniques related to trigonometric functions.
  • Participants discuss reformulating the expression for easier integration, with suggestions to use trigonometric identities. There are attempts to apply the double angle formula and explore different forms of the function to facilitate integration.
Some participants have provided hints and guidance on using trigonometric identities and substitution methods. There is an ongoing exploration of different approaches to simplify the integral, with no explicit consensus reached on a single method.
Participants mention that this is an assignment question, indicating constraints on the type of help being sought. There is also a note about changing some values in the expression, though the argument of the trigonometric functions remains unchanged.
tomwilliam
Find the area of the region between x=-pi/6 and x=pi/4 above the x-axis and below the graph of:
I know I need to reformulate the expression somehow so that it is easier to integrate, and I'm guessing it's a double angle formula like:
cos (2x) = 2 cos^2 x -1
but I can't seem to bring it all together to find something I know how to integrate.
Any hints? This is an assignment question, so I'd like to know how to do it properly. I've also changed a few of the values (but not the argument of the trig functions).
good. so far youre off to a good start. use that trig identity and play around with it once you substitute that in your integral.
You guess well, but use the formula in the opposite way, to make cos^2 (2x) disappear. You can integrate cos2x and cos4x.
ehild
I'm a little confused by that...if I use the formula the opposite way to get cos^2 to disappear, I get back to what I started with.
At the moment I've changed the cos(2x) and expanded the brackets to get:
16 cos^2 (x) - 7 - 4 cos^4 (x)
I'm not sure if I'm any closer or not.
You are thinking about it the wrong way. You have
f(x) = 8 cos(2x) - cos^2 (2x)
You could easily do u sub, so 8 cos(u) - cos^2(u). Integrating cos is easy, but what about cos^2?
Ah yes, I see now.
Thanks all.
  • · Replies 105 ·
13K
  • · Replies 36 ·
9K
