Spherically symmetric metric form
  • Context: Graduate
  • Thread starter Thread starter mersecske
    Form Metric Symmetric
The discussion revolves around the interpretation and characteristics of spherically symmetric metrics in general relativity. Participants explore different forms of the metric, their implications for vacuum solutions, and the conditions under which these forms apply, particularly in relation to static and non-static spacetimes.
  • Some participants present different forms of the spherically symmetric metric and inquire about their interpretations and general applicability.
  • One participant argues that the first metric form represents the most general spherically symmetric metric, while the others are special cases with specific choices of functions.
  • Another participant references Birkhoff's theorem, stating that the unique vacuum solution is the Schwarzschild spacetime, but questions arise about the applicability of the metric forms to non-vacuum solutions.
  • Concerns are raised regarding the definition of static spacetimes, particularly in relation to the Schwarzschild metric and its singularity at the event horizon.
  • Participants discuss the implications of coordinate choices, such as Kruskal-Szekeres coordinates, for covering the Schwarzschild metric and the potential for coordinate singularities.
  • There is a debate about whether all spherically symmetric spacetimes can be expressed in the discussed metric forms, with some asserting that non-static spacetimes can also fit this description.
  • Questions are posed about the existence of a general non-singular spherically symmetric metric and the limitations of covering manifolds with single coordinate patches.
Participants express differing views on the applicability of the metric forms to various spacetimes, particularly regarding the necessity of static conditions and the implications of singularities. No consensus is reached on the precise statements regarding the generality of the metric forms or the definition of static spacetimes.
Participants note limitations in the definitions and assumptions surrounding the metrics, particularly concerning coordinate choices and the nature of singularities in the Schwarzschild solution. The discussion highlights the complexity of defining static versus non-static spacetimes and the challenges in expressing metrics without singularities.
mersecske
spherically symmetric metric used to write in he following form:
ds^2 = -h(r,t}^2 * dt^2 + f(r,t)^2 * dr^2 + r^2 * d_omega^2
But what about the form
ds^2 = -f(r,t}^2 * dt^2 + f(r,t)^(-1) * dr^2 + r^2 * d_omega^2
and
ds^2 = -f(r}^2 * dt^2 + f(r)^(-1) * dr^2 + r^2 * d_omega^2
how can we interpret these forms?
This is the general spherically symmetric vacuum solution, or what?
Since in your first equation f and h can be whatever functions you like (yes, in this way you get the most general spherically symmetric metric) the last two equations are just special cases of the first one (i.e. with particular choices of f and h).
For any spherically symmetric spactime, even one that is not a vacuum solution, coordinates exist such that its metric can be expressed in your h(r,t), f(r,t) form.
In the case of a vacuum solution, Birkhoff's theorem says that the unique solution (up to a choice of coordinates) is the Schwarzschild spacetime. For the Schwarzschild spacetime, it's possible to choose coordinates such that you get the f(r), 1/f(r) form. See http://www.lightandmatter.com/html_books/genrel/ch07/ch07.html#Section7.3 , subsection 7.3.7. If f(r) is chosen arbitrarily, then your f(r), 1/f(r) form will not in general be a vacuum solution; only if f(r) is chosen to be of the Schwarzschild form 1-2m/r is it a vacuum solution.
Yes I know that spherically symmetric metric has the first form in general,
however the precise statement is "spherically symmetric and STATIC" as I know!
But my question is:
Can we say something similar about the second and third one in general?
I mean: All "..." spacetimes has the form...
and the form... always describes "..."
Not only the Schwartzschild but de Sitter or charged BH has the same form with f(r).
And I have another question:
most textbooks said that spherically symmetric and STATIC spacetimes
can be described with a metric in the first form.
However this is not true because the Schwarzschild metric has a singularirty at the event horizon! What is the precise statement?
I've read what you have linked,
but at section: 7.3.6 Birkhoff's theorem
the author(s) write "time" when t is used,
however t is not time in general,
because t is not time-like coordinate below the horizon!
So I think this is not a precise textbook.
At and below the event horizon, Schwarzschild spacetime is not static.
A spacetime is static or not static isn't it?
How can define "static" locally?
So what is the precise statement for the first metric form?
or
general spherically symmetric and static metric?
No.
If U is a connected open subset of a spacetime M, then U is itself a spacetime. U could be static, while M\U is not.
I'm pretty sure you're incorrect about this. First, there are definitely non-static spacetimes, such as FRW cosmological solutions, that can be put in the first form. Also, I believe it is true that all spherically symmetric spacetimes can be put in this form. If you have a copy of Hawking and Ellis, take a look at their proof of Birkhoff's theorem. They pretty clearly state that the metric can be put in this form in general, and then they write down the non-vacuum field equations, including source terms. Only later do they specialize to the case of a vacuum solution, and then the final result of the proof is that the spacetime is of the Schwarzschild form, which is static outside the horizon. If they had to assume staticity in order to write down the metric in that original form, then their proof would be logically erroneous, because they'd be assuming what is essentially the main result of the proof: staticity.
Is the claim that (a) all spherically symmetric and static spacetimes can be put in that form, or (b) that any spacetime that can be put in that form is spherically symmetric and static? Claim b is clearly false, since cosmological solutions are a counterexample. Claim a is true, but unnecessarily weak, since the assumption of staticity is unnecessary.
But what about the metric at the horizon?
The event horizon of a Schwarzschild BH is also spherically symmetric,
but you cannot put the metric in the first form!
One thing I hadn't noticed before is that you were talking about the form
[tex]ds^2 = -h(r,t)^2 dt^2 + f(r,t)^2 dr^2 + r^2 d\Omega^2[/tex] ,
whereas Hawking and Ellis are using the more general form
[tex]ds^2 = -h(r,t)^2 dt^2 + f(r,t)^2 dr^2 + g(r,t) d\Omega^2[/tex] .
I think their form can be used to cover the entire Schwarzschild metric, including the horizon, since the metric has this form when expressed in Kruskal–Szekeres coordinates (with t->V, r->U, g->r).
I don't know whether it is possible to cover the Schwarzschild spacetime with coordinate patches, each of which gives a metric in your form, without any coordinate singularities. Do you have an argument to show that this is impossible? You can do any coordinate transformation of the form [itex]t\rightarrow t'=f(t,r)[/itex] while still keeping the metric in your form.
I'm glad you pointed this out, because it is definitely a possible weak point in my own version of the proof, which I linked to in #3. I'll have to think about it more. I'm not sure that it's a terribly big issue to have a coordinate singularity on a particular surface.
Another thing to be careful about is that many authors, such as Ludvigsen, use the term "stationary" to mean asympotically stationary, so some statements they make may seem incorrect unless you take into account their definition of the term.
[EDIT] I found a discussion of this point in Misner, Thorne, and Wheeler, section 32.2. On p. 843 they introduce the form with [itex]r^2 d\Omega^2[/itex], then note that it may fail to apply on certain 3-surfaces, and suggest in an exercise on p. 845 how to remove these coordinate singularities.
Ok, thanks! And Kruskal-Szekeres or Eddington-Finkelstein like coodinates can be used in general to any spherically symmetric metric? What is the form of a general spherically symmetric metric, which is not singular anywhere?
I general you can't cover a manifold with a single coordinate patch; if you could, then the definition of a manifold would be a lot simpler! Therefore I don't think there is any such general form.
I don't say single just non-singular.
For example Schwarzschid coordinates is good below and above the horizon,
but not on the horizon.
I'd suggest you study the proof in Misner, Thorne, and Wheeler, section 32.2, and figure out what goes wrong in the places where [itex]\nabla r=0[/itex]. I suspect that the form you're talking about can't be applied at all in a place like this, but I haven't thought it through in enough detail. For the proof of Birkhoff's theorem, all that matters is that the places where it fails to have that form are 3-dimensional rather than 4-dimensional. It would surprise me very much if you could cover the entire Schwarzschild spacetim4e with patches that all had the form you're talking about, and that were all smooth and well-behaved.
  • · Replies 50 ·
  • · Replies 18 ·
  • · Replies 16 ·
  • · Replies 26 ·
