Finding position and velocity from Force (analytic mechanics)
The discussion focuses on deriving the velocity and position of a mass "m" repelled from the origin by a force defined as F(x) = k/x³. The user successfully derived the velocity function v(x) = √(k/m)(x₀⁻² - x⁻²) but encountered discrepancies when attempting to integrate v(x) with respect to time to find x(t). The correct approach involves integrating dx/v(x) = dt to derive the time-dependent position function x(t) = √(kt²/mx₀²) + x₀², confirming that the initial expression for v(x) is valid.
  • Understanding of Newton's Second Law (F = ma)
  • Familiarity with calculus, specifically integration techniques
  • Knowledge of force functions in physics, particularly inverse power laws
  • Basic concepts of kinematics and motion equations
  • Study integration techniques for functions involving velocity and time
  • Learn about force functions and their applications in analytic mechanics
  • Explore the derivation of motion equations from force laws
  • Investigate the relationship between potential energy and force in physics
Students of physics, particularly those studying mechanics, as well as educators and anyone interested in the mathematical modeling of motion under force.
PhysicsMark
A body of mass "m" is repelled from the origin by a force F(x). The body is at rest at x_0, a distance from the origin, at t=0. Find v(x) and x(t).
[tex]F(x)=\frac{k}{x^3}[/tex]
[tex]\ddot{x}=\frac{d\dot{x}}{dt}=\frac{dx}{dt}\frac{d\dot{x}}{dx}=v\frac{dv}{dx}[/tex]
I first perform the following steps:
[tex]F=ma=m\ddot{x}=\frac{k}{x^3}[/tex]
[tex]\int{v{dv}}=\int_{x_0}^{x}\frac{k}{mx^3}dx[/tex]
[tex]\frac{v^2}{2}=\frac{-k}{2mx^2}+\frac{k}{2m{x_0}^2}[/tex]
[tex]v(x)=\sqrt{\frac{k}{m}(x_{0}^{-2}-x^{-2})}[/tex]
The next step is to integrate v(x) WRT time. Doing this will solve for the position. My homework states that x(t) should be:
[tex]x(t)=\sqrt{\frac{kt^2}{mx_{0}^{2}}+x_{0}^{2}}[/tex]
If I integrate v(x) WRT time, I will get a different answer for position than the equation above. Is my expression for v(x) incorrect?
You should integrate v(t) over time and not v(x).
As you don't have v(t) you can instead write
dx/dt=v(x) , separate the variables and integrate both sides.
I mean, integrate
dx/v(x)= dt
You'll get t = some function of x. Then solve for x and you'll get x(t).
