Calculating Heat & Work for 1 Mole of Ideal Gas
The discussion revolves around calculating heat and work for a monatomic ideal gas undergoing a state change. The initial and final states are defined by specific pressure, volume, and temperature values, with a non-linear pressure-volume relationship provided. Participants are exploring the implications of changing variables throughout the process.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the challenges of applying equations when multiple variables are changing. There are attempts to use the area under the curve for work calculation and considerations of the first law of thermodynamics. Some express confusion about the validity of their results and the assumptions made regarding the process.
The discussion is active, with participants providing various insights and suggestions. Some have offered alternative approaches to calculating work and heat, while others are questioning their understanding of the underlying principles and the implications of their findings. There is no explicit consensus, but several productive lines of inquiry are being explored.
Participants are navigating the complexities of thermodynamic equations and the implications of sign conventions. There is acknowledgment of mistakes and misconceptions as part of the learning process, with references to previous parts of a cyclic reaction affecting the current problem.
kalbuskj31
1 mole of monatomic ideal gas. P1 = 2 atm V1 = 44.8 L T1 = 1092 K. The path to P2 = 1 atm V2 = 22.4 L and T2 = 273K is P = 6.643E-4 * V^2 + 2/3. Calculate the heat and work.
q = nCpΔT
w = PΔV
I attempted to directly plug in the data that was available and didn't work. Neither P,V, or T are constants during this state change. I just realized in posting this problem I'm not sure what equation to use since every variable is changing. Suggestions?
q = -13.5kJ w = -3278 J
You need to use the more general definition of work:
[tex]W=\int P\,dV[/tex]
You'll also want to use the first law to solve the problem.
I was able to find work by figuring out the area under the curve.
The solution that I found for q baffles me. This question was the last part of a series of state changes in a cyclic reaction. I found the answer by adding the q and subtracting w from the previous parts of the problem. That shouldn't work like that right?
You are given the change in temperature so you can easily determine [itex]\Delta U[/itex]. You have figured out the work done. So apply the first law to find heat flow:
[tex]\Delta Q = \Delta U + W[/tex]
AM
I suggest memorizing now these two formulas
dU = dW + dQ (for work done on the environment)
dW = d(pV)
dW = d(pV)
Except that it should be dQ = dU + dW then, where dW is the work done BY the gas/system (ie. ON the surroundings).
AM
Thanks, I did some alegbra incorrectly and stumbled across something that I found very very unusual. Is it safe to assume what I found is a rare coincidence?
I am not sure what you did. Your formula for dq = nCpdT is incorrect, since this is not a constant P process. You determine dQ by finding the work done (by integrating PdV (substituting the given formula for P) and the change in U (using change in temperature) and then applying the first law.
AM
Ah, my bad, I got the sign convention wrong. I hate that thing. I should have looked it up. :(
Anyway, my advice still holds, memorize those formulas and learn how to use them because you'll see more as you go through thermo.
Oh yeah, and also kalbuskj, mistakes are invaluable. Sometimes you'll learn more than you ever could in getting the problem wrong and figuring out why it is wrong then getting it right to begin with. Don't just work the problem with the goal of getting it right, work it with the goal of finding your misconception, fixing it, and reworking the problem with the right concepts.
