Thread Closed
is the trajectory of a ball with friction calculable?
Share Thread Thread Tools
Aug25-10, 04:04 PM   #1
I have written a simulation for school that simulates balls being thrown under the influence of friction.
To check if my results are correct, do you know if it is possible to calculate the trajectory?
I can use the friction formulas of either stokes or newton. Is it possible to calculate how far a ball will fly for either of those?
Wikipedia shows formulas for a free fall, but I don't think that suffices, as there is only one coordinate that changes in that case.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Iron-platinum alloys could be new-generation hard drives
>> Lab sets a new record for creating heralded photons
>> Breakthrough calls time on bootleg booze
Aug25-10, 07:04 PM   #2
2 words. Drag and lift.
Balls produce lift when spinning, see Magnus effect.
A sphere has an inherent drag, and you can find the answer to that from 'drag on a sphere'. Both lift and drag will be influenced greatly by Reynolds number. If this is modelling something real then you are going to have turbulent flow, so stokes' equations are out.
How have you modelled this?
Aug26-10, 05:34 AM   #3
the program I wrote simulates the trajectory in realtime by dividing time in fragments and iterating. In each iteration, the simulation applies the acceleration the ball would experience to its speed and its speed to its location. For sufficiently small iteration lengths the simulation is precise enough.
The drag force is included (along with gravity and lift), the spin is not. I have decided not to include it to make it simpler for myself. Also, the drag coefficient is assumed to be constant throughout the simulation (if newton's formula is used). I don't use Reynold's number at all. Is that important? It works just fine without it.
Back to my question: to compare my simulation's results with something, is it possible to calculate the tryjectory directly (for either stokes' or newton's formula for drag)? I'm guessing not, but I want to make sure.
Aug26-10, 07:24 AM   #4
That's all fine, there are different levels of complexity for a model like this, all are valid, you just need to list the assumptions made (in this case a constant drag coefficient).
It's not possible to calculate the trajectory in any other way than you are doing it. If there was an easy equation to do this, there would be no point in doing a numerical?
I did something very similar using excel back in Uni.
Aug26-10, 11:49 AM   #5
Good to hear this. I knew it was impossible for stokes' law, but thought that some sites explained it for newton's. I didn't understand any of it, though, so I wanted to make sure.
Thanks for confirming my assumptions.
Aug26-10, 06:51 PM   #6
Quote by xxChrisxx View Post
A sphere has an inherent drag...
Interestingly enough, a spinning sphere has less drag that a non-spinning one.
Aug26-10, 07:06 PM   #7
Quote by mugaliens View Post
The Cd also drops significantly after a critical Re number, after this the Cd value stays vitually constant.
When spinning there is also an induced drag component, meaning that to kick a ball the furthest the launch angle is less than 45 degrees, about 37 seemed to give the best results iirc.
Interesting, but not really relevent to the OP's question.
Thread Closed
Thread Tools
Similar Threads for: is the trajectory of a ball with friction calculable?
Thread Forum Replies
Trajectory of a Base Ball Introductory Physics Homework 2
Playground ball trajectory. Introductory Physics Homework 3
spinning ball and its trajectory General Physics 6
Trajectory of curving ball Introductory Physics Homework 2
ball rise trajectory Introductory Physics Homework 3
