| Thread Closed |
Why does particle displacement A increase sound pressure? |
Share Thread | Thread Tools |
| Aug28-10, 04:15 PM | #1 |
pressure=p(x,t)=BkAsin(kx-ωt)
http://www.physics.unomaha.edu/Sowel...ound/Sound.pdf Surely, when loudness-intensity-pressure increases, so does the maximum displacement A of the speaker. Wrong thread title. My question is: Why increasing the maximum molecule displacement A increases sound pressure. They also say that the A of the speaker is equal to the maximum displacement "A" of the molecule. Why that? |
| Aug28-10, 04:19 PM | #2 |
| Aug28-10, 04:43 PM | #3 |
That's not an answer. I can understand the assumption that it is so for the molecule that is "always in contact" with the speaker (assuming something per average etc as it moves before the speker starts moving). But why should this apply for all other molecules too?
| Aug29-10, 04:17 PM | #4 |
Why does particle displacement A increase sound pressure?You could say that it is an assumption. The assumption then allows for a model that is sufficiently close to reality, where each molecule has an average position. You may also want to read about the model for sound waves in solids which is closely related: http://en.wikipedia.org/wiki/Phonon |
| Aug29-10, 07:14 PM | #5 |
What about my first question: (assuming that the A of the speaker is equal to the A of each molecule):Why increasing the maximum molecule displacement A increases sound pressure?
Is it because when the A of the molecule increases then the maximum speed umax=(√(k/m))A=ωΑ=2πfA and all other speeds also increase? And if indeed so, then that's the only reason? |
| Aug29-10, 08:43 PM | #6 |
Now that slide on pressure. V is volume and S is the area of a plane parallel to the speaker. B is the bulk modulus of the medium (air). The math shown is then pretty straightforward. The end result pmax=BkA simply shows that if A increases, so must pmax, linearly. You just can't argue with that math. |
| Aug30-10, 02:57 AM | #7 |
I am not arguing with the math. I am asking what they are claiming. If you do not know the answer do not answer me that "there is an answer".
B is constant, so does k, right and the function of sin can only take values between 1 and -1, right? So the Pmax and (?) the Σ|p(t)|dt of a period or half a period, is dependent on A only. And I am asking why that. One answer is that the max speed of each molecule increases as A increases, and its average speed doubles when A doubles because the period T remains the same (see also the simulation http://www.ngsir.netfirms.com/englishhtm/Lwave.htm) So its seems that the reason is the increase of speed of the molecules (note that all molecules in a wavefront are moving towards the same direction as the wavefront). So I am asking whether I concluded correctly and whether the increase of their speed is the only reason. And because I get such answers from physists, now I changed my mind and I AM "arguing with the math". The doubling of the speed just because the A of the speker doubled a little, means that there is a considerable increase at temperature, which is false or at least it seems to contradict that "the speed of sound in air is 343 for room temperature no matter what the speaker does". So what's going on: What have I grasped wrong or what is wrong. |
| Aug30-10, 07:04 PM | #8 |
I thank you sir for giving me the opportunity to review sound, and I hope I was at least a little helpful. |
| Sep6-10, 03:41 PM | #9 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Why does particle displacement A increase sound pressure?
| Particle displacement vs time graph of sound. How can this happen? | General Physics | 7 | ||
| Pressure increase | Introductory Physics Homework | 2 | ||
| Pressure and Displacement sound waves. Pressure always lead? | General Physics | 2 | ||
| LHC particle mass increase | Special & General Relativity | 13 | ||
| displacement and pressure in sound wave | Introductory Physics Homework | 1 | ||
