How Do You Find the Concentration of I- in the Iodine Clock Reaction?
  • Thread starter Thread starter TrueStar
    Clock Reaction
The discussion revolves around determining the concentration of iodide ions (I-) in the Iodine Clock Reaction, focusing on the calculations involved in dilution and reaction rates. Participants explore the relationships between concentrations of reactants and the effects of mixing solutions in a laboratory setting.
  • Homework-related
  • One participant proposes using the equation m1v1=m2v2 to find the concentration of I- after mixing solutions, noting the initial concentrations of KI and other reactants.
  • Another participant confirms that since KI dissociates into K+ and I-, the concentration of I- in the solution is equal to the concentration of KI, which is 0.200 M.
  • A different participant discusses the dilution effect when mixing solutions and emphasizes the need to calculate the final volume for accurate concentration determination.
  • One participant raises a question about calculating the rate of reaction for I- based on the consumption of thiosulfate, mentioning the need to consider stoichiometric coefficients in the rate equations.
  • The same participant provides a detailed calculation process for determining the rate of iodine formation, involving the initial concentration of thiosulfate and the time taken for the reaction.
Participants generally agree on the basic principles of dilution and the dissociation of KI into I-. However, there is some uncertainty regarding the application of stoichiometric coefficients in rate calculations, with differing interpretations of how to apply these in the context of the Iodine Clock Reaction.
Participants express uncertainty about the assumptions involved in dilution calculations and the additive nature of volumes when mixing solutions. There is also a lack of consensus on the correct application of stoichiometric coefficients in rate equations.
TrueStar
Find the concentration of I- involved in the Iodine Clock Reaction
I think this will involve m1v1=m2v2 --- but I am not sure.
We did nine 'iodine clock' reactions to demonstrate chemical kinetics. I'll use the second one as an example.
We added 7.50mL of 0.200 M KI, 2.50ml of 0,200 KCl, and 5.00mL of 0.0050 S2O32-, and one drop of starch to one flask. We then added 5.00mL of S2O82- to another flask.
We then mixed them together in a beaker. The total amount of solution is 20mL. It turns dark blue/black in about a minute.
I need to figure out the concentration of I-. I understand that the reaction I need to investigate is:
2I-(aq)+S2O82-(aq) [tex]\rightarrow[/tex]I2+2SO42-
I'm not sure how I can get the concentration from this. I know how to get the concentration of KI, but I don't know how to get only the I-.
Again, I think it has to do with the equation listed above, but I'm not sure.
I've read up more on this and think I have my answer.
KI is ionic, so in a solution the salt will turn into K+ and I-.
Since KI is one to one, if 0.200 M of KI, that means I have 0.200 M of I-. Is this correct?
You have 0.200M I- in the solution that you mixed with others - which is (from the pov of I-) just a dilution.
And yes, dilution can be calculated with C1V1 = C2V2. See http://www.chembuddy.com/?left=concentration&right=dilution-mixing. You will just need final volume, which can be easily calculated assuming volumes are additive. In general they are not, but differences are negligible in this case.
Yes, that makes sense. Yesterday made for a nice refresher course in dilutions and ionic solutions.
I have another question concerning the Iodine Clock; I don't think the lab instructor was entirely clear on getting the rate from the timing agent.
He said that in order to find the rate for I-, use the following equation
[tex]\Delta[/tex][S2O32-] / [tex]\Delta[/tex]t
I understand that our initial concentration for thiosulfate is always the same at 1.25x10-3 and that the final concentration will always be zero since it's used up.
However, don't the coefficients need to be considered? The equation in question is:
I2(aq)+2S2O32-(aq)[tex]\rightarrow[/tex]2I-+S4O62-(aq)
That tells me that the rate for thiosulfate should be multiplied by -1/2 and the iodine should be multiplied by -1.
For example, my first iodine clock reaction took 50 seconds for the starch-iodine complex to appear. I started with 1.25x10-3 concentration of thiosulfate. Using the rate equation, I end up -1.25x10-3 and divide that by 50 since that's how many seconds the reaction took. That gives me an answer of -2.5x10-5, but then I must multiply this by -1/2 because the coefficient of the thiosulfate in the chemical reaction is 2. This gives me 1.25x10-5. I then multiply this by 50 (since this equals the change of concentration of iodine divided by the change in time which is 50 seconds) and that will give me the rate for iodine.
Am I on the right track? I want to be sure, because I have eight other reactions to calculate and graph.
