Relative atomic mass of an element ?
The discussion revolves around calculating the relative atomic mass of neon based on the percentages of its isotopes. It includes a mathematical approach to the problem and addresses the concept of why relative atomic masses are not whole numbers.
  • Homework-related, Mathematical reasoning, Conceptual clarification
  • One participant presents a calculation for the relative atomic mass of neon based on the isotopic composition but is unsure about the division step.
  • Another participant suggests dividing the sum by 100 to obtain the correct relative atomic mass.
  • A third participant confirms their calculation of 20.16 after applying the suggested method.
  • There is a question about why relative atomic masses are not whole numbers, with a suggestion that it is due to the presence of isotopes.
Participants generally agree on the method for calculating the relative atomic mass and the reason for non-whole number values, but there is no explicit consensus on the initial calculation method.
Some calculations depend on the correct application of percentages, and there is a lack of clarity on the initial approach to the problem.
faisal
relative atomic mass of an element ?
A sample of neon was found to cotain 90.9% of 20Ne, 0.26% of 21Ne, & 8.8% of 22Ne, Calculate the relative atomic mass of neon.
this is what i'v done so far (90.9x 20)+ (0.26x21)+(8.8x22)= 2017/?
i don't know what to divide it by :confused: ? I'm not given a mass spectra?
P.s.
why r relative atomic masses for some elements not whole numbers, is it because they r isotopes?
Chemistry news on Phys.org
Divide by 100.
That will get you 20.17
Yes, they are not whole numbers because of isotopes. That's what you're taking account for by finding the relative atomic mass.
Thanx, i did the question again and i got 20.16 this is what i did (90.9/100x20)+(0.26/100x21)+(8.8/100x22)= 20.16
Either way works. :)
