Register to reply
Range of 3d function?
by Khan
Tags: function, range
Share this thread:
Khan
#1
Sep12-04, 11:45 AM
P: n/a
I'm not sure how to approach this problem:
Find the range of f(x,y) = Ax^2 + 2Bxy + Cy^2 (Answer will be in terms of A, B, and C)
Thanks! And we haven't yet been allowed to use partial derivatives, so they can't be used to solve it.
Phys.Org News Partner Science news on Phys.org
Flapping baby birds give clues to origin of flight
Prions can trigger 'stuck' wine fermentations, researchers find
Socially-assistive robots help kids with autism learn by providing personalized prompts
e(ho0n3
#2
Sep12-04, 11:54 AM
P: 1,367
This question is rather vague. What is the domain of f? And why do you say the answer will be in terms of A, B, and C? Maybe you're asking for something else?
Khan
#3
Sep12-04, 11:59 AM
P: n/a
I agree that it's vague, but that's how the question was given to me. I assume the domain is all real numbers, and wouldn't the range have to depend on A, B, and C?
Khan
#4
Sep12-04, 12:06 PM
P: n/a
It may be helpful if you helped me with a different question, and maybe then I could figure this one out on my own:
find the range of f(x,y) = x^2 + xy + y^2 + 2x - 4y over the domain of all reals
e(ho0n3
#5
Sep12-04, 12:37 PM
P: 1,367
OK. I understand now. Basically you're asked to find the global extremum. Are you really not allowed to use partial derivatives?
Khan
#6
Sep12-04, 12:44 PM
P: n/a
Yeah we really aren't. We're supposed to use algebra or single variable calculus only.
arildno
#7
Sep12-04, 02:08 PM
Sci Advisor
HW Helper
PF Gold
P: 12,016
Quote Quote by Khan
1.Eliminate the cross-product term in the following manner:
[tex]x(u,v)=u\cos\theta-v\sin\theta[/tex]
[tex]y(u,v)=u\sin\theta+v\cos\theta[/tex]
Hence we have:
[tex]x^{2}+xy+y^{2}=u^{2}+v^{2}+\frac{u^{2}-v^{2}}{2}\sin(2\theta)+uv\cos(2\theta)[/tex]
By choosing [tex]\theta=\frac{\pi}{4}[/tex], we may rewrite f in terms of u and v like this:
[tex]f=\frac{3}{2}u^{2}+\frac{1}{2}v^{2}+\fsqrt{2}(u-v)-2\sqrt{2}(u+v)[/tex]
Furthermore:
[tex]f=\frac{3}{2}(u^{2}-\frac{2\sqrt{2}}{3}u)+\frac{1}{2}(v^{2}-6\sqrt{2}v)[/tex]
Or:
[tex]f=\frac{3}{2}(u-\frac{\sqrt{2}}{3})^{2}-\frac{2}{3}+\frac{1}{2}(v-3\sqrt{2})^{2}-9[/tex]
Finally:
[tex]f=\frac{3}{2}(u-\frac{\sqrt{2}}{3})^{2}+\frac{1}{2}(v-3\sqrt{2})^{2}-\frac{29}{3}[/tex]
Clearly, we must have:
[tex]f\geq-\frac{29}{3}[/tex]
Tide
#8
Sep12-04, 03:53 PM
Sci Advisor
HW Helper
P: 3,144
Why not just transform to polar coordinates?
[tex]f(x, y) = f(r, \theta) = r^2 \left(A \cos^2 \theta + B \cos \theta \sin \theta + C \sin^2 \theta \right)[/tex]
It should be obvious then what the range is.
arildno
#9
Sep13-04, 02:10 AM
Sci Advisor
HW Helper
PF Gold
P: 12,016
You've forgotten the linear terms, Tide!
It might well be that polar coordinates provide simpler expressions..
Tide
#10
Sep13-04, 02:14 AM
Sci Advisor
HW Helper
P: 3,144
Quote Quote by arildno
First, there aren't any linear terms so you're probably talking about the cross terms! I didn't forget them! What I did was to accidentally drop the factor of two in the coefficient of xy. Thanks for pointing me to my error!
arildno
#11
Sep13-04, 02:19 AM
Sci Advisor
HW Helper
PF Gold
P: 12,016
OK, I was looking at the f-function given in post 4, not the one given in post 1!
While polar coordinates might be instructive in post 1, it's also quite simple to use the axis-rotation technique proposed:
Given:
[tex]Ax^{2}+2Bxy+Cy^{2}[/tex]
We have, introducing u and v:
[tex]Du^{2}+uv(2B\cos(2\theta)+(C-A)\sin(2\theta))+Ev^{2}[/tex]
Or, in general, we may use:
[tex]tan(2\theta)=\frac{2B}{A-C}[/tex]
to eliminate the cross-product term.
The signs of D and E will then determine the range.
ehild
#12
Sep13-04, 04:58 AM
HW Helper
Thanks
P: 10,627
Quote Quote by Khan
First investigate the cases when one or more coefficients are zero. This is relatively easy. If all are zero the range is zero. If B is not zero but both A and C are zero, f can take any real values.
Now we assume that B=0 and at least one of A and B is not zero.
If B=0, f(x,y) = Ax^2+Cy^2.
[tex] \mbox{ If } A\geq 0 \mbox{ and } C \geq 0 \mbox{ than } f \geq 0[/tex]
[tex] \mbox{ If } A\leq 0 \mbox{ and } C \leq 0 \mbox{ than } f \leq 0[/tex]
If A<0, B>0 or A>0, B<0 f can be either positive or negative, and can have any values in the range of real numbers.
Now assume that A is not zero. Then you can rewrite the function as
[tex]f(x,y)=A[x^2+\frac{2B}{A}xy+\frac{C}{A}y^2]=A[(x+\frac{B}{A}y)^2+\frac{CA-B^2}{A^2}y^2]=[/tex]
[tex]=A(x+\frac{B}{A}y)^2+(C-\frac{B^2}{A})y^2[/tex]
Now you can apply the previous argument.
If
[tex] A> 0 \mbox{ and } C-\frac{B^2}{A} \geq 0 \mbox{ then } f(x,y) \geq 0[/tex]
if
[tex] A< 0 \mbox{ and } C-\frac{B^2}{A} \leq 0 \mbox{ then } f(x,y) \leq 0 [/tex]
if the sign of both coefficients are different f can take any real values.
If A=0 but C is not, you can arrive to the range by factoring out C first.
ehild
Register to reply
Related Discussions
Range Of Function Calculus & Beyond Homework 1
Range of a function Calculus & Beyond Homework 1
Range of a function General Math 8
Range of a function question Calculus & Beyond Homework 1
What are the domain and range of this function? Set Theory, Logic, Probability, Statistics 7
