What Explains the Minus Sign in Weyl Spinor Products?
  • Context: Graduate
  • Thread starter Thread starter earth2
    Spinors Weyl
The discussion revolves around the minus sign encountered in the products of Weyl spinors, particularly in the context of supersymmetry and field theory. Participants explore the implications of Grassmannian character and the transformation properties of spinors under Lorentz transformations, as well as the definitions and roles of different types of spinors.
  • One participant notes that the spinor product of two left-handed Weyl spinors exhibits a minus sign, questioning its origin despite similar definitions in different contexts.
  • Another participant explains that the minus sign arises from the nature of the spinors being used, differentiating between classical fermions represented by Grassmann numbers and quantum fermions represented by anticommuting fields.
  • A participant expresses confusion about the use of Grassmann numbers in decomposing null vectors, seeking clarification on the definition of Weyl spinors and their properties.
  • Further clarification is provided regarding the transformation properties of Weyl spinors and the necessity for their components to be commuting numbers when expressing four-vectors, contrasting this with the use of Grassmann numbers in other contexts.
Participants express differing views on the appropriate use of Grassmann numbers versus commuting numbers in the context of spinor products and transformations. The discussion remains unresolved regarding the precise conditions under which each type of spinor should be employed.
The discussion highlights the dependence on definitions and the specific goals of using spinors, with unresolved questions about the implications of these choices on the properties of the resulting mathematical expressions.
earth2
Hey guys,
I have a question about said spinors.
In supersymmetry introductions one finds (e.g. for two left-handed spinors [tex]\eta[/tex], [tex]\nu[/tex]) that [tex]\eta\nu=\nu\eta[/tex] due to their Grassmannian character and the antisymmetry of the spinor product.
If I look, however, at modern field theoretical methods that rely on the fact that SO(3,1) is doubly covered by SL(2,C) to express 4-vectors in terms of Weyl spinors, I find for the spinor product of two left-handed Weyl spinors (in a slightly different notation) [tex]\langle \nu |[/tex], [tex]\langle \eta |[/tex] is given by
[tex]\langle \nu |\eta\rangle=-\langle \eta |\nu\rangle[/tex].
I don't see where the minus-sign enters, since in my view only the notation is different, whereas the definition of the spinor product is the same in the two cases...
Does someone know where the difference comes from?
Cheers,
earth2
I had a great many arguments about those minus signs. We finally did track it down. Suppose we're working with spinors A and B whose components are complex (commuting) numbers. The definition of the inner product is AB = epsilon_mn A^m B^n = -epsilon_nm A^n B^m = -epsilon_nm B^m A^n = -BA.
Now, suppose that instead they're either grassmann numbers or fermionic fields. In that case, the second to last step requires an anticommutation, which kills off the minus from the previous line, leaving you with = BA.
Thus, there are different kinds of spinors depending on your goal. If the spinor is to describe a classical fermion, use grassmann numbers. If it's to describe a quantum fermion, use anticommuting fields. If you're just decomposing a null vector in terms of spinors (for example, p^mu -> sigma_mu p^mu = lambda_a lambda_adot), then use complex numbers.
Thanks for the reply! :)
I still don't get one subtle thing about the "goal":
Why don't I use grassmann numbers when i decompose a nullvector? I mean, all I do is to use the isomorphism between SO(3,1) and SL(2,C), i.e. i express all my four vectors via Weyl spinors...But suddenly they don't have grassmannian entries anymore...
I am confused...
Edit: Btw, what is the precise definition of a Weyl spinor? Perhaps that sheds some light on the problem...?
All I mean is something that transforms under the 2 rep of SO(1,3)/the fundamental of SL(2,C).
Suppose I made the fourvector p^mu = (E, 0, 0, E). In order to write it in terms of Weyl spinors, i'd form sigma dot p = ((2E, 0), (0, 0)) and then factor it into a column vector times a row vector. In this case, I'd say lambda = ((sqrt(2E)), (0)) and lambdabar = (sqrt(2E), 0). I can do that, but if I want p to transform like a fourvector under lorentz transformations, I have to insist that lambda transforms like a left-handed spinor and lambdabar like a right-handed one. (Maybe I have it backwards; I forget.) Doing that reproduces the correct transformation properties on p.
What's clear from this example is that the components of lambda and lambdabar MUST be commuting numbers; if we had used grassmann numbers we wouldn't have complex-valued numbers at the end of the day, but rather more grassmann numbers.
If, instead, you were to start the day by saying I want lambda to represent the state of a fermion, then you find that, via the spin-statistics connection, that spinor components must anticommute with other spinor components. The two methods of doing that are to make it grassmann-valued in the classical case, or anticommuting operators in the quantum case.
  • · Replies 20 ·
