Gravity of Moon & Roller Coaster Proof Help
This discussion addresses two physics problems related to projectile motion and centripetal acceleration. The first problem calculates the gravitational acceleration on the Moon, concluding that it is one-sixth that of Earth's gravity, derived from the relationship between the distances a golf ball travels on both celestial bodies. The second problem involves analyzing the apparent weight difference on a roller coaster during a vertical loop, demonstrating that this difference is consistently 6g's, independent of the loop's size or speed, as long as the speed exceeds the minimum required.
  • Understanding of kinematic equations in physics
  • Knowledge of projectile motion principles
  • Familiarity with centripetal acceleration concepts
  • Basic grasp of gravitational forces on different celestial bodies
  • Study the derivation of gravitational acceleration on different celestial bodies
  • Learn about the principles of projectile motion and its equations
  • Explore centripetal acceleration and its applications in roller coasters
  • Investigate the effects of friction on motion in circular paths
Students and educators in physics, engineers designing amusement park rides, and anyone interested in the mechanics of motion in different gravitational fields.
Klinger
I would appreciate any hints or help in solving the following two physics problems. At this point I am stuck after trying to solve the problems for a while.
1. Apollo astronauts hit a golf ball on the moon 180 meters and 30 meters on earth. Assume that the swing, launch angle, etc are the same on the moon and earth. Assume no air resistance.
We know that Vxo and Vyo is the same on both the moon and Earth (Vxo is the initial velocity in the x direction). We also know that tmoon = tearth *(180/30).
I try substituting these values into the kinematic equations for projectile motion but get stuck. Vy are different for Earth and moon and thus there are too many unknowns.
2. Show that on a roller coaster with a circular vertical loop the difference in your apparent weight at the top of the loop and the bottom of the loop is 6g's. Ignore friction. Show also that as long as your speed is above the minimum needed, this answer doesn't depend on the size of the loop or how fast you go through it. Assume that roller coaster starts traveling from height h and the radius of the loop is R.
My approach was to calculate the ratio of the centripidal acceleration as it exits the loop divided by the centripidal acceleration at the top of loop. I calculate the decease in velocity due to the elevation gain of 2R. But I don't seem to get the expected answer.
Thanks for any help.
:bugeye:
for your first question, are you asked for the gravity on the moon?
then you can use this:
On earth:
[tex]V_{earth}^{2} = V_{o\ earth}^{2} + 2ad[/tex]
[tex]V_{earth}^{2} - V_{o\ earth}^{2} = 2a(1)[/tex]
[tex]V_{earth}^{2} = V_{o\ earth}^{2} = 2a[/tex]
On moon:
[tex]V_{moon}^{2} = V_{o\ moon}^{2} + 2ad[/tex]
[tex]V_{moon}^{2} - V_{o\ moon}^{2} = 2a(\frac{30m}{180m})[/tex]
[tex]V_{moon}^{2} = V_{o\ moon}^{2} = \frac{1}{3}a[/tex]
Since the initial and final speed are the same, we can eqate the two:
[tex]2a = \frac{1}{3}a[/tex]
[tex]a_{moon} = \frac{1}{6}a_{earth}[/tex]
[tex]g_{moon} = \frac{1}{6}g_{earth}[/tex]
I think you can do the second one yourself.
A Couple of Clarification Questions
I have a couple of questions:
-- in the 2nd "earth" equation why did you set d=1?
-- in the 2nd "moon" equation why did you set d=30/180?
On earth:
On moon:
  • · Replies 16 ·
9K
