Electron Orbital: Learn About Probability and Bounds
  • Context: Graduate
  • Thread starter Thread starter mishima
    Electron Orbital
The discussion revolves around the concept of electron probability density in quantum mechanics, particularly in relation to the bounds of this density and the implications of potential energy environments, such as those found in hydrogen atoms and other systems. Participants explore the theoretical aspects of where an electron might be found, including the implications of infinite potential and the nature of electronic orbitals.
  • Some participants propose that the bounds of the probability density depend on the potential energy environment, with examples like the Coulomb potential in hydrogen atoms and square wells.
  • It is suggested that, in principle, an electron could be found light years away from the nucleus, although the probability drops off exponentially and becomes insignificantly low very quickly.
  • One participant argues that the only regions where probability density is zero are those with infinite potential, such as at the origin in the hydrogen atom.
  • Another participant challenges this by stating that the ground-state hydrogen electron has a finite probability of being at the nucleus, asserting that the highest probability density occurs there.
  • There is a discussion about the distinction between probability density and radial probability distribution, with some participants clarifying that the latter is zero at r=0 due to the lack of surface area.
  • Participants debate the implications of nodes in electronic orbitals and how they relate to the concept of delocalization, with some emphasizing that nodes do not negate the existence of probability density in bound systems.
Participants express multiple competing views regarding the nature of electron probability density, particularly in relation to the nucleus and the implications of potential energy. The discussion remains unresolved, with no consensus reached on several key points.
Limitations include the dependence on definitions of probability density and radial probability distribution, as well as unresolved mathematical steps regarding the implications of infinite potentials and the behavior of wave functions at specific points.
mishima
Hello,
I'm a bit confused learning about how an electron can be found anywhere within the probability density. What exactly are the bounds of the probability density? Could the electron (with an insanely low probability) be found light years away from the nucleus?
The bounds depend mostly on the potential energy environment around the particle (e.g. electron). For example: for a hydrogen atom, the potential energy is mostly determined by the coulomb force
[tex] U \propto - \frac{1}{r}[/tex]
or for a 'square well' (like an electron between capacitor plates) the potential is zero between the plates, and some number outside the plates.
The only time (generally) that the electron probability density will be zero, is in regions with (or separated off by) and infinite potential. In the hydrogen atom example, the potential is infinite only at the origin (r = 0), and thus there is zero probability density there. Everywhere else in the universe (of that hypothetical and ideal hydrogen atom), even light years away, there is some probability of finding the electron. Within very short distances, however, the probability becomes so small that you would never statistically expect to find the electron there in the entire age of the universe... but it would still be, 'possible.'
To answer the OP: Well, yes, in principle. But it does drop off exponentially, and becomes insignificantly low very quickly.
Err, no. Electronic orbitals (with the exception of 1s orbitals which have no nodes) have lots of nodes where there are quite finite potentials. And infinite potential does not mean a zero probability density, because that singularity may be canceled by the kinetic energy term. Hence:
Is also wrong. The ground-state hydrogen electron (1s) has a quite finite probability of being at the nucleus, not only that, it's the most likely place - a volume element at r=0 has the highest possible probability density. You're confusing the probability density with the radial probability distribution, which is not the same thing. The latter is zero at r=0 because a sphere of radius zero has no surface area.
I think you're missing the forest a little here.
Yes, absolutely, entirely correct. But the only place, where generally and systematically the probability will tend to be zero... is at infinite potentials (e.g. infinite square well). Nodes do pop up all over the place in bound systems, but I don't find that point to be at all illustrative to the general concept of delocalization. I should have been more clear, my apologies to the OP.
Right again, I mis-spoke, I meant probability, not probability density. But, alxm, I don't see how you can say there is a finite probability at r=0--for just the reason you state, the volume is zero.
But this isn't the case for (generalized) Coulomb potentials, which are the only potentials of interest in this context.
I said 'a volume element', I didn't refer to the volume of a single point. Choose a box or sphere of whatever volume you like. If you want to maximize the density in it, it must be centered at x=y=z=0. The 1s wave function is exp(-r), and the density distribution merely the square of that.
The density distribution is n(x,y,z), the radial density distribution is this function integrated over the surface of a sphere of radius r. That will obviously go to zero as r->0, regardless of what the density distribution happens to be.
  • · Replies 21 ·
  • · Replies 20 ·
  • · Replies 36 ·
10K
