"Change in Entropy for Iron/Aluminum Equilibrium
  • Thread starter Thread starter slicknick
    Change Entropy
The discussion centers on calculating the equilibrium temperature and change in entropy for a system involving a 10 gram block of iron and a 20 gram block of aluminum. The final equilibrium temperature is determined to be 319.9 K using the equation q=m(Sp)(ΔT). The confusion arises regarding the application of specific heat capacity (Sp) in the entropy change formula, ΔS = ∫Cp*dT/T, and how to calculate the entropy change for the surroundings in a closed system. The participants clarify that the correct approach involves using the specific heat capacities and ensuring proper unit conversions.
  • Understanding of specific heat capacity (Sp) and its application in thermal equilibrium.
  • Familiarity with the first law of thermodynamics and heat transfer concepts.
  • Knowledge of entropy and its mathematical representation in thermodynamic processes.
  • Ability to perform unit conversions and integrate basic thermodynamic equations.
  • Study the derivation and application of the entropy change formula, ΔS = ∫Cp*dT/T.
  • Explore examples of heat transfer between different materials to solidify understanding of thermal equilibrium.
  • Learn about the implications of entropy changes in isolated systems and the concept of the universe's entropy.
  • Investigate the relationship between heat transfer and work done in thermodynamic systems.
Students in thermodynamics, physics enthusiasts, and anyone studying heat transfer and entropy in closed systems will benefit from this discussion.
slicknick
A 10 gram block of iron metal (Sp=0.449 J/gK) at 400 K is placed in contact with a 20 gram block of aluminum (Sp=0.903 J/gK) at 300 K. Heat flows between the two until equilibrium is reached. Find the equilibrium temp and the change in entropy for the process.
q=m(Sp)([tex]\Delta[/tex]T)
and for a process involving a temperature change i think we use:
[tex]\Delta[/tex]S = [tex]\int[/tex]Cp*dT/T
First of all I was able to find the final temperature by using the first equation. It should be = 319.9 K. Where I get confused is do I use the Sp in place of Cp and then integrate? The reason I don't think I am doing this right is because there is a problem almost identical to it in the book (except that the metals and masses are the same) and I can't even get close to a right answer. Also in the one in the book, it asks for the change in the entropy for the universe and says that it is a positive non-zero number. How can that be true if the system is isolated and even if it isn't isolated how could you calculate the entopy change for the surroundings? I've tried it every way I can think of. please help!
So you know that T final is the same for the two, and you are given T initial. Because the two systems are connected, they are related almost by a Newton's 3rd law type of relation (that the heat lost of one is the heat gain of another).
In any case like this, you just have to make sure the units are what you want to report. If you used your cited equation they wouldn't work to simply replace Cp with Sp.
dS/dU=1/T, and there is no work done, so dS/dQ=1/T. dQ=mSp*dT in this case so... dS = mSp*dT/T.
Oh yeah that's what I was doing. You also have to multiply by the mass in order to cancel the units of grams so that your units are J/K. I guess then that I just don't understand the question that was similar or that its answer is wrong.Thanks for your help.
  • · Replies 60 ·
11K
