Minimum Force to Make an Object Move
  • Thread starter Thread starter uchicago2012
    Force Minimum
To determine the minimum force required to move a 6 kg object on a surface with a coefficient of friction of 0.8, the maximum static friction force (Fsmax) must be calculated. The normal force (Fn) equals the weight of the object, which is 58.8 N. The force of friction (Ff) is then calculated as 47.088 N, using the formula Ff = coefficient of friction * weight. To initiate movement, any applied force must exceed this frictional force. The discussion emphasizes the importance of recognizing static equilibrium conditions in solving such problems.
uchicago2012
A 6 kg object sits on a horizontal surface with coefficient of friction = .8. What is the minimum force (not necessarily horizontal) necessary to make the object slide?
Fsmax = u * Fn
where Fsmax is the force that must be overcome to make an object move, u is the coefficient of friction, and Fn is the normal force.
I was just wondering if this seemed correct:
Fg = -58.8 N (mass * g) so
Fn = 58.8 N
I'm not clear on when exactly one can make the assumption that Fg = Fn
but then using that value of Fn I calculated Fsmax, so the minimum force necessary to make the block move is any force greater than Fsmax.
You need to overcome the force of friction.
The force of friction is
Ff=(coefficent of friction)(weight of object in Newtons)
Ff=(.8)(6*9.81)
Ff=(.8)(58.86)
Ff=47.088N
I think :D
One can always make the assumption that, if the acceleration in some coordinate direction is zero, then by Newton's second law, the sum of all forces acting along that direction must be zero.
This condition for static equilibrium is the foundation for all introductory statics problems.
TL;DR Summary: Find Electric field due to charges between 2 parallel infinite planes using Gauss law at any point Here's the diagram. We have a uniform p (rho) density of charges between 2 infinite planes in the cartesian coordinates system. I used a cube of thickness a that spans from z=-a/2 to z=a/2 as a Gaussian surface, each side of the cube has area A. I know that the field depends only on z since there is translational invariance in x and y directions because the planes are...
