Target Practice: Calculating Bullets & Angles for 200m Range
  • Thread starter Thread starter physicsss
    Brain
The discussion revolves around calculating the trajectory of a bullet aimed at a target 200 meters away, considering factors such as bullet speed and gravitational effects. The subject area includes kinematics and projectile motion.
  • Participants explore the time it takes for the bullet to reach the target and the vertical displacement due to gravity. There are attempts to apply kinematic equations to determine how much the bullet will miss the target and the angle required to hit it.
Some participants have provided calculations and questioned the accuracy of their significant figures. Others have suggested alternative methods for analyzing the problem, including the use of trajectory formulas. The conversation reflects a mix of interpretations and approaches without a clear consensus on the best method.
Participants are working within the constraints of a homework assignment, which may limit the information available for solving the problem. There is an ongoing discussion about the assumptions made regarding the bullet's trajectory and the effects of gravity.
physicsss
A shooter aims directly at a target on the same level 200 m away.
a) If the bullet leaves the gun at a speed of 250 m/s, by how much will it miss the target?
b) At what angle should the gun be aimed so the target will be hit?
The bullet will travel horizontally at 250 m/s, thus making the nearest encounter with the target at 200/250 = 0.8 s. In this time, how much will the bullet have fallen from its original position? Remember that the acceleration due to gravity is 9.8 m/s2. The answer to (b) should immediately follow.
For part a, I used the equation y2=y1+v1*t-1/2*g*t^2
since y1=0 and v1=0 in the y-direction, the equation is left with y=1/2*g*t^2
y=-1/2*(-9.8)*0.8^2=3.14 (is my sig figs correct?)
For b, I used v^2=v1^2-2gy, since at halfway distance is 100m and v=0 in the y direction, equation becomes
0=(sin(x)*250)^2+2*9.80*100
x=10.2
Is this and the sig figs right?
nevermind. thanks for the link
Actually, the nearest encounter will occur somewhat earlier than that! :smile:
But you're really interested in the time it takes for the horizontal distance traveled by the bullet to equal the original distance to the target.
Yeah, that's what I meant. I just didn't know how to put it in words. :blushing: So I opted to put it the way I did, without realising that it was wrong.
  • · Replies 17 ·
15K
