General solution of trig functions
The discussion revolves around finding the general solutions for trigonometric equations involving sine and cosine functions. The specific equations are sin x = 1/√2 and cos x = 0.5, with participants exploring the reasoning behind the general solutions and the implications of periodicity in trigonometric functions.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the original poster's attempts to derive general solutions and express curiosity about the second solutions for sine and the reasoning behind the plus/minus notation for cosine. There is also a suggestion to sketch the functions to better understand the solutions.
The discussion is ongoing, with participants sharing insights about the graphical interpretation of the functions and questioning the completeness of the original methods. Some guidance has been offered regarding the periodic nature of sine and cosine, but there is no explicit consensus on the methods to derive the general solutions.
Participants note the importance of understanding the periodic properties of trigonometric functions and the implications of symmetry in the unit circle. There is also mention of the need for clarification regarding negative angles in the context of the tangent function.
t_n_p
Find the general solution of:
a) sin x = 1/[tex]\sqrt{2}[/tex]
b) cos x = 0.5
a) x = asin(1/[tex]\sqrt{2}[/tex])
x = (π/4) + 2nπ
b) x = acos(0.5)
x = π/3 + 2nπ
Basically, my strategy was to solve for the basic angle, and then add multiples of the period (2nπ for sin and cos, nπ for tan).
However, the answers provided are:
a) x = 2nπ + asin(1/[tex]\sqrt{2}[/tex])
or x = (2n+1)π - asin(1/[tex]\sqrt{2}[/tex])
b) 2nπ ± acos(1/2)
Just wondering,
for a) how do they find the second solution x = (2n+1)π - asin(1/[tex]\sqrt{2}[/tex])? I'm curious to know, as the follow on question asks for the first 2 positive solutions to sin x = 1/[tex]\sqrt{2}[/tex], which can apparently only be obtained using both answers shown above. I only know how to get the first solution
for b) where does the ± come from? My answer is the same but for ±.
thanks in advance
hmm interesting.
got an email notification saying there was a reply to this thread, but there is nothing here!
guess posted must have deleted!
Have you sketched both of them and tried to reason by looking at the sketches? It should be quite helpful to do that.
Some things to note; cos is an even function as you'll see when you sketch it which is related to the +-.
Sin is an odd function, and therefore is unlikely to have just one solution for all, hopefully when you sketch it you'll see that.
I understand graphically how the solutions are valid, but is there a set method/recipe to obtain these results?
Would it be right ro assume, that for the cos question, my method is correct, it just needs the plus/minus in there?
as for the sin question, how they get the second general solution is still a puzzle to me...
Just adding multiples of 2pi is not enough (saying that sin(x) has period 2pi means that if y and x differ by a multiple of 2pi, then sin(x)= sin(y). It does NOT say that if sin(x)= sin(y) then they must differ by a multiple of 2pi.
One way to remember the connections is to think of sine and cosine in terms of the unit circle. If (x, y) is a point on the unit circle so that the radius make angle [itex]\theta[/itex] with the positive x-axis, then [itex]x= cos(\theta)[/itex] and [itex]y= sin(\theta)[/itex]. That means that 2 angles, [itex]\theta[/itex] and [itex]\phi[/itex], between 0 and [itex]2\pi[/itex] will have the same sine if they lie on same horizontal line (same y value) and such a line will intersect the unit circle twice: by symmetry, [itex]\phi= \pi- \theta[/itex]. Similarly with cosine and a vertical line: [itex]cos(\theta)= cos(2\pi- \theta)[/itex].
ok yep, definitely see what you are saying (halls of ivy).
when I look at sin, positive in 1st and 2nd quadrants, then when I look at the solutions it makes sense. same with cos, positive in 1st and 4th quadrants, the plus minus accounts for this.
Naturally this leads to the following question:
find general solution of:
tanx = -3/[tex]\sqrt{3}[/tex]
x = atan(-3/[tex]\sqrt{3}[/tex])
tan negative in 2nd and fourth quadrants, so general equation(s) are
(2n-1)π - atan(-3/[tex]\sqrt{3}[/tex])
2nπ - atan(-3/[tex]\sqrt{3}[/tex])
Sound good?
bump.
the negative in the atan(...) is bothering me.
I still need to be convinced!
bump
still seeking clarification with the negative case
  • · Replies 19 ·
