Showing a (complex) series is (conditionally) convergent.
The discussion focuses on the convergence of the series \(\sum^\infty_{n=1} \frac{1}{n} z^n\) within the open unit ball and specifically examines the case when \(|z| = 1\). It is established that while the series diverges for \(z = 1\), it converges for all other values on the unit circle. The key to proving this convergence lies in demonstrating that the related series \(\sum^\infty_{n=1} z^n\) is bounded for \(|z| = 1\) and \(z \neq 1\). The discussion highlights the need to analyze the behavior of the truncated series as \(N\) approaches infinity.
  • Complex analysis fundamentals
  • Understanding of series convergence and divergence
  • Knowledge of bounded sequences
  • Familiarity with limits and the behavior of sequences as \(N \to \infty\)
  • Study the properties of bounded sequences in complex analysis
  • Learn about the convergence criteria for power series
  • Explore the implications of the Weierstrass M-test for uniform convergence
  • Investigate the behavior of series with complex arguments, particularly on the unit circle
Students and professionals in mathematics, particularly those specializing in complex analysis, as well as anyone interested in the convergence properties of series in complex domains.
shoescreen
I've been reading a complex analysis book which had an example showing [tex]\sum^\infty_{n=1}1/n \cdot z^n[/tex] is convergent in the open unit ball.
I'm now looking at the case when [tex]|z| = 1[/tex]. Clearly [tex]z = 1[/tex] is the divergent harmonic series, but i know this series is in fact convergent for all other [tex]|z| = 1[/tex].
In order to prove this, i need to be able to show that the related series [tex]\sum^\infty_{n=1}z^n[/tex] is bounded, whenever [tex]|z| = 1[/tex] and [tex]z \neq 1[/tex],.
I can solve this problem when ever the argument of z is a rational multiple of pi, but other than that I'm stuck. Any help proving that this related series is bounded would be very helpful.
Thanks!
If you sum the truncated (at N) series, you have (1-zN+1)/(1-z). For z=1, you have 0/0 (no good). For z≠1, the expression is well defined, so see what happens as N -> ∞.
  • · Replies 22 ·
