Thread Closed
Show that matrices of defined form have inverse of the same same defined form
Share Thread Thread Tools
Sep22-10, 09:27 AM   #1
Given the set of 3x3 matrices of the form: [1, a, b; 0, 1, c; 0, 0, 1], where a, b, and c are any real numbers show that the inverses of these matrices are of the same given form.
2. Relevant equations
Using elementary row operations, transform [A:I] into [I:A-1].
Inverse of a 3x3 matrix
3. The attempt at a solution
This is a subsection of a problem in which I am attempting to show that the set of these 3x3 matrices are a group under matrix multiplication. I was able to prove that it is well-defined, closed, an identity exists, and that associativity holds. For the inverse, it was simple to show that this set of 3x3 matrices is non-singular, but the trouble I'm running into is showing that the inverse is of the same given form so that closure still holds.
Thanks for any assistance.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Sep22-10, 09:37 AM   #2
Mentor
Quote by donald17 View Post
What trouble are you having? Finding the inverse is straightforward, and yields the inverse in just a few steps. The inverse has the same form.
Sep22-10, 10:27 AM   #3
Actually I just solved it. Thanks.
Thread Closed
Thread Tools
Similar Threads for: Show that matrices of defined form have inverse of the same same defined form
Thread Forum Replies
MATLAB user defined inverse fourier transform Engineering, Comp Sci, & Technology Homework 1
recursively defined numbers, need to show they are non-decreasing Linear & Abstract Algebra 0
canonical form of matrices Precalculus Mathematics Homework 9
3x3 similar matrices defined by characteristic and minimal polynomials Linear & Abstract Algebra 3
Having troubles putting matrices in another form, linear combination form i think. Introductory Physics Homework 14
