Thread Closed
Tangental acceleration from given centripetal acceleration and a range of radii
Share Thread Thread Tools
Sep22-10, 01:53 PM   #1
Hi, how can I determine the tangental acceleration of a circle needed to produce a given centripetal acceleration from a range of radii? For example, I would like to produce 9.81 m/s/s centripetal acceleration with a range of radii from 5km to 100km? All I really need is to figure out the equation and I can write a program to graphically display the results.
Here's what I've found so far:
ac = vt2/r
centripetal acceleration = (tangental acceleration)2 / radius of circular path
Fc = mvt2/r
centripetal force = mass x ((tangental speed)2 / radius of circular path)
If centripetal force is different than centripetal acceleration and a weight is needing to determine the newtons involved then assume that the object being acted upon weighs 80 earth kg.
Thanks for any help! If you could just nudge me in the right direction I'd appreciate it very much.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Sep22-10, 02:43 PM   #2
You dont need a tangential acceleration to produce a given centripetal acceleration, all you need is a given tangential speed. This can be calculated from the first formula you gave.
Vt^2=r*a_c
where r are the different radii and a_c is the centripetal acceleration.
Sep22-10, 02:52 PM   #3
... d'oh
That seems so obvious now.
Anyways, that means that an asteroid with a 137km circumference ring drilled into it (the longest manmade tunnel so far) would need to be accelerated to a spin 59.4km/h (instantaneous velocity tangental to the ring) to produce 9.81 m/s2 acceleration... artificial gravity, anyone?
Thread Closed
Thread Tools
Similar Threads for: Tangental acceleration from given centripetal acceleration and a range of radii
Thread Forum Replies
centripetal acceleration Introductory Physics Homework 3
Centripetal Acceleration Introductory Physics Homework 3
Centripetal Acceleration and Tangential Acceleration problem driving me crazy! Introductory Physics Homework 1
Centripetal Acceleration Introductory Physics Homework 2
Centripetal acceleration, incorporating a change in acceleration around the circle... Introductory Physics Homework 3
