Net Ionic Equations: NaCl + AgNO3 Reaction
  • Thread starter Thread starter b.barkey
    Ionic Net
The discussion revolves around the net ionic equation for the reaction between aqueous sodium chloride (NaCl) and aqueous silver nitrate (AgNO3). Participants explore the dissociation of these compounds in solution, the formation of precipitates, and the proper representation of the net ionic equation.
  • Homework-related
  • One participant initially confuses sodium chloride with sodium chlorite (NaClO2) and seeks help in writing the net ionic equation.
  • Another participant corrects the formula, clarifying that sodium chloride is NaCl and suggests writing the compounds in their ionic forms.
  • There is a discussion about the charges of the ions, particularly the need to correctly represent the charge on silver (Ag+).
  • Participants mention the solubility rules and the formation of a precipitate (AgCl) when mixing the salts, while noting that Na+ and NO3- remain in solution as spectator ions.
  • One participant expresses uncertainty about how to write the final net ionic equation, asking if it should be Ag+(aq) --> Cl-(s).
  • Another participant confirms the precipitation of AgCl but challenges the idea that NO3- attaches to Na+, emphasizing that they remain as spectator ions in the solution.
Participants generally agree on the formation of AgCl as a precipitate, but there is some disagreement regarding the treatment of spectator ions and the correct formulation of the net ionic equation. The discussion remains unresolved regarding the final representation of the net ionic equation.
Participants have not fully resolved the steps to derive the net ionic equation, and there are missing assumptions regarding the definitions of spectator ions and the conditions under which the reaction occurs.
b.barkey
So the question is:
Enter the net ionic equation for the reaction of aqueous sodium chloride with aqueous silver nitrate.
So i know that the first part of the equation is:
Na(ClO2)aq+Ag(NO3)aq --> i have no clue what should go here.
Please help
and i don't ebern know how to attempt this problem... i tried:
Ag(aq) --> (ClO2)s
because this is what would change but it is saying it is not right.
NaClO2 is not sodium chloride.
Start writing both compounds in ionic form, the way they dissociate in the solution. Don't ignore charges.
Close, just add correct charge to Ag.
Do you have any idea what can happen when you mix these salts? Hint: answer lies in the solubility rules.
The Charge on Ag is a + right but my professor said something about in the Net ionic equation how all the reactents are not in it. so i was wondering how i would write the end equation... would it be:
Ag+(aq) --> Cl-(s) or something like that..
Try to answer my question: what will happen in the solution?
www.titrations.info, www.chemistry-quizzes.info, www.ph-meter.info
the soluble ployatomic ion NO3 would attach to the Na and the Ag would attach to the Cl and the AgCl would become a solid while the Na(NO3) would still be aq... right?
Yes and no. You are right about AgCl precipitating from the solution and becoming solid, you are wrong about NO3- attaching to Na+ - they will just float in the solution, they aren't called spectators without a reason.
Now you should be able to write full ionic equation and cancel out spectators.
  • · Replies 16 ·
9K
