Investigate the range of complexes formed by transition elements
This discussion focuses on the formation of complexes by transition elements, specifically copper complexes. The reactions involved include the formation of CuCl4^2- ions from Cu(H2O)6^2+ in the presence of sodium chloride and the conversion of copper hydroxide to tetraminecopper hydroxide using ammonia. Stoichiometry can be applied to calculate the concentrations and moles of reactants and products, provided the molarity and volume of the reactants are known. The reactions discussed demonstrate the importance of ligand concentration and the role of water as a ligand in complex formation.
  • Understanding of transition metal chemistry
  • Knowledge of complex ion formation
  • Familiarity with stoichiometry and molarity calculations
  • Basic principles of aqueous solution chemistry
  • Study the formation and properties of transition metal complexes
  • Learn about ligand exchange reactions in coordination chemistry
  • Explore stoichiometric calculations in chemical reactions
  • Investigate the role of ligands in determining the stability of metal complexes
Chemistry students, laboratory technicians, and researchers interested in transition metal complexes and their applications in chemical reactions.
dagg3r
We mixed 3 ml of 1M copper solfate solution and 3ml of sodium chloride solution.
This main copper ions are presented as Cu(h20)6 2+
We heated the test tube to produce cucl42- ions.
This is part a)
We placed 1M of copper2 sulfate solution in anoter test about 2 cm depth and slowly added 1 M sodium hydroxide solution and a thick precipitate formed.
We added 2M ammonia solution to this mixture and cy(Nh3)4 2+ ions are formed.
This is part b)
Is it possible to use stoichiometry to calculate the respective concentration, num of moles of them all
Ie
Initaially
Reaction
Equilibrium.
Chemistry news on Phys.org
Yes, it is possible, for all reactions, that you may calculate the stoichiometry of almost all reactions, providing that you know molarity and volume of reactants.
Aqueous copper sulfate exists as [Cu(H2O)6]SO4. You know molarity and volume, so just multiply them with each other to obtain the mole amount. You'll get 3 mmol.
[Cu(H2O)6]SO4 + 4 NaCl ---> Na2[CuCl4] + Na2SO4 + 6 H2O
This reaction is only possible in the presence of high chloride concentrations; water is a stronger ligand and it is not very easy to remove complexed water from the complex.
You formed a copper hydroxide precipitate (light blue) by adding sodium hydroxide; and then added ammonia to convert this into tetraminecopper hydroxide:
CuSO4 + 2NaOH --> Cu(OH)2 + Na2SO4
Cu(OH)2 + 4NH3 --> [Cu(NH3)4](OH)2
You'll need to know the final volume of the reaction medium; then you can calculate the concentrations as inorganic reactions have yields as much as about 95-100%
Regards, chem_tr
16K
