Help! Factor Trinomial with X^3: Sample Problem Included
  • Thread starter Thread starter jacksonbobby5
    Factoring
The discussion focuses on factoring the trinomial X^3 - 2X^2 + 1. Participants suggest starting by factoring out an X, but this approach is incorrect. The correct method involves using the rational root theorem to identify potential factors or applying factoring by grouping. The expression can be rewritten as x^3 - x^2 - x^2 + 1, allowing for further simplification through grouping.
  • Understanding of polynomial expressions
  • Familiarity with the rational root theorem
  • Knowledge of factoring techniques, specifically factoring by grouping
  • Basic algebra skills, including manipulation of algebraic expressions
  • Study the rational root theorem and its application in polynomial factorization
  • Learn the technique of factoring by grouping with examples
  • Practice factoring higher-degree polynomials, particularly cubic expressions
  • Explore additional polynomial identities and their uses in simplification
Students learning algebra, educators teaching polynomial factorization, and anyone seeking to improve their skills in manipulating cubic expressions.
jacksonbobby5
I need help trying to factor a trinomial. It has been a while, and I can't remember how to factor a trinomial with x^3. Please help.
Sample problem...
X^3 - 2X^2 + 1
Thanks
Not sure where to start, I would think I would factor out an X
Maybe: X^2 (1X - 2 + 1)
Sample problem...
X^3 - 2X^2 + 1
Thanks
well I would say [tex]x^2(x-2) +1[/tex] insteed. But maybe its just me...
Sample problem...
X^3 - 2X^2 + 1
Thanks
This is incorrect. If you simplify the expression in parentheses, you get x - 1. If you then multiply x^2 and x -1, you get x^3 - x^2, which is different from what you started with.
If you are being asked to factor polynomials such as this one, it's possible that you have learned about the rational root theorem. It gives you a way to find the potential factors of the polynomial, based on the coefficients of the highest and lowest degree terms in the polynomial.
If you haven't learned this theorem, your polynomial can still be factored using another technique called factoring by grouping.
x^3 - 2x^2 + 1 = x^3 - x^2 - x^2 + 1
Group together the first two terms on one group, and the last two terms in another group. Can you continue from here?
36K
  • · Replies 24 ·
  • · Replies 19 ·
