A couple specific Physics problem solving questions
This discussion focuses on effective problem-solving techniques in introductory Physics courses. Key strategies include avoiding premature numerical substitutions, organizing equations symbolically before plugging in values, and ensuring unit consistency throughout calculations. Participants emphasize the importance of visual aids, such as diagrams, and suggest using common sense to verify the behavior of equations. These methods are crucial for developing strong analytical skills and creativity in Physics problem-solving.
  • Understanding of basic Physics concepts and terminology
  • Familiarity with algebraic manipulation of equations
  • Ability to interpret and create diagrams for mechanics problems
  • Knowledge of unit conversion and dimensional analysis
  • Research techniques for effective diagramming in Physics problems
  • Learn about dimensional analysis and its application in verifying equations
  • Explore common sense checks for equations in Physics
  • Study problem-solving strategies specific to mechanics and kinematics
Students in introductory Physics courses, educators teaching Physics problem-solving techniques, and anyone looking to enhance their analytical skills in scientific contexts.
DrummingAtom
I'm in my first ever Physics class and have a few questions concerning skills involving solving Physics problems. I've been noticing that even though I get the right answers, my work getting there is a mess and unorganized. With that said, I have a hunch that won't fly in the upper level classes, which is why I'm trying to figure this out early.
When you're working on a problem do you try to stay away plugging in numbers too early? Like if a problem needs to have several things found to arrive at the final answer, do you make one large equation with only symbols *then* plug in numbers at the very end?
Also, when you get to the end of that a distinct relationship is found among the symbols. Is there anything from a creativity aspect that you do to gain more insight into the problem? I know this question seems a little strange, but I'm pretty new to Physics and want to develop some skills with solving problems as well as some creativity. Thanks.
A few tips.
1, Draw a diagram - especially for any mechanics type problems
2, Don't put in the numbers until you have the equations rearranged/solved.
3, When you have the equations worked out, check that the units balance.
4, Although you shouldn't put in numbers too early you do need to have an estimate of the answer - or at least the magnitude of the answer. This is especialy important for astronomy/chemistry type questions with very large/small numbers. It's easy to be a factor a million out because you got a unit wrong or mistyped a calcuator button
Yes, exactly.
Yes, at this point I check if the behavior of the equation agrees with what I know from common sense (or other knowledge I have). Just for example,
  • As one variable is increased, does the result increase or decrease?
  • As one variable is increased, does the result go through a maximum or minimum?
  • What is the result when one variable is zero?
  • What value of the variable would cause the result to be zero?
  • What is the result when one variable approaches infinity?
  • Do the units on both sides of the equation agree? Do the units of terms that are added or subtracted agree?
If the answers to those questions conflict with how I know things should be, that's a signal that I have made a mistake somewhere.
  • · Replies 21 ·
  • · Replies 23 ·
