Cliff Height Calculation: Rock Drop & Sound Travel
The problem involves calculating the height of a cliff from which a rock is dropped, with the sound of the impact heard 3.00 seconds later. Given the speed of sound at 340 m/s, the approach requires separating the total time into two components: the time of free fall (t1) and the time for sound to travel back up (t2). Using the formula for free fall distance, d = (1/2)gt1^2, and the relationship t = t1 + t2, the height of the cliff can be determined accurately.
  • Understanding of kinematic equations, specifically free fall motion.
  • Knowledge of the speed of sound in air at sea level (340 m/s).
  • Ability to manipulate algebraic equations to solve for unknowns.
  • Familiarity with basic physics concepts such as acceleration due to gravity (approximately 9.81 m/s²).
  • Study the kinematic equations for free fall to reinforce understanding of motion under gravity.
  • Learn how to derive and apply the formula for the distance traveled by sound in a given time.
  • Explore real-world applications of sound travel time in various mediums.
  • Investigate the effects of altitude and temperature on the speed of sound in air.
This discussion is beneficial for physics students, educators, and anyone interested in solving real-world problems involving motion and sound propagation.
monkeyboy726
rock is dropped from cliff. it is heard hitting the ocean 3.00s later, if speed of sound is 340m/s, how high is the cliff?
im so stuck
try d= (at^2)/2
a = acceleration
t = time
d = distance
use the speed of sound in dry air at sea level to solve.
Hi -
This is how I would approach this problem...
Draw a sketch to represent the situation. As you can see, the rock is in free fall from y (the height of the clift to the ground) to the ground (y = 0). The soundt travels with uniform speed the distance y (upward). Let t1 be the time of the free fall and t2 the time of the sound traveling up. Then, the total time is t = t1 + t2 = ?. Then, use the free fall formula to get time t1 and then solve for the height of the clift.
Good luck :smile:
