What is causing my 1/4 NPT fittings to not fit together properly?
  • Thread starter Thread starter axemaster
    Fitting
The issue with the 1/4 NPT fittings not fitting together properly stems from the discrepancy in thread specifications between the tap and die. The tap, marked "1/4 NPT 18," indicates it has 18 threads per inch (TPI), while the die labeled "1/4 NPT Baystate -5" lacks a TPI specification, suggesting it may not conform to the standard. This misalignment leads to improper threading and fitting at an angle. The "-5" designation on the die is likely a manufacturer-specific code rather than an indication of thread size or pitch.
  • Understanding of NPT (National Pipe Taper) thread standards
  • Familiarity with threading tools, specifically taps and dies
  • Knowledge of thread pitch and its impact on fitting compatibility
  • Basic skills in pipe fitting and assembly techniques
  • Research the specifications of various NPT fittings and their thread counts
  • Learn about the differences between various tap and die manufacturers
  • Investigate the implications of thread pitch on fitting compatibility
  • Explore troubleshooting techniques for misaligned threaded fittings
This discussion is beneficial for plumbers, pipe fitters, and anyone involved in mechanical assembly or maintenance requiring precise fitting of threaded components.
axemaster
Ok, so here's a weird problem. I am trying to make a 1/4 npt fitting with two pieces of brass pipe.
The tap says:
Vermont
1/4 NPT 18
HSGG M21
The die says:
1/4 NPT
Baystate -5
So I threaded the pieces of pipe, expecting them to fit together nicely... and they didn't - far from it. I found that they were screwing in at an angle, and stopping after a short distance.
Needless to say I'm mystified by this. I've tried threading several pieces, being careful to make nice straight threads, and still this problem remains. I suspect it must have something to do with that "-5" on the die, but I haven't been able to find any references explaining what it means.
Please help!
I would imagine because it isn't a 1/4 NPT 18 die. I don't know what "baystate -5" means and I don't think it has to do with the die size (manufacturer maybe?). Regardless, your die probably just doesn't have 18 threads per inch like the tap does.
12K
14K
9K
