Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Physics > General Physics
Notices
Reply
image light ray problem Share It Thread Tools Search this Thread image
Old Sep16-04, 09:49 AM                  #1
7bear
7bear is Offline:
light ray problem
1. If a light ray go through a boundary of air and glass(i.e. angle of incidence is 90 degree), Is there any refraction or reflection?
2. If angle of incidence is 0 degree( the light ray is normal to a glass), Is there any reflection?
3. Suppose the situation is same as (2), but the light ray go from air to water. Is there any refraction or reflection?
Old Sep16-04, 11:16 AM                  #2
kuenmao
kuenmao is Offline:
1. Light can either go through the air next to the glass, or the glass next to the air. There's no such thing as a boundary that can be travelled through. So I guess if you do it very accruately, the answer depends on where you enter the glass from air.
2. Yes. A very weak one. You don't see it, however, because it coincides with light beam that is travelling towards the glass block.
3. Whenever something is going normal to the surface, then it won't have any refraction. Refraction occurs only when the incident ray is at an angle to the surface. However, there will be a (weak, very weak) refracted ray.
Old Sep16-04, 06:09 PM                  #3
Nenad
Nenad is Offline:
1. Yes, there is refration and reflection. If you look at a piece of blass in front of you, you will see the stuff behind it and you will also see a faint mirror image of yourself. This is called partial reflection, and it has a LOT to to with quantum physics. It wanges anywhere from 4% to 16%. But this is a long stody.
2. Look at my answer to number 1.
3. Water, I am not shure of. Im not shure if the same phenomenon happens as in glass, but by experience, it seems to me that there is both.
Old Sep19-04, 07:55 PM                  #4
Claude Bile
Claude Bile is Offline:
Recognitions:
1. Yes, there is still reflection. There is no refraction in the sense that the light ray does not bend, however it is still generally referred to as a refracted ray.
2. The Fresnel reflections from an air glass interface is about 4%. Antireflection coatings on the surface of the glass can reduce this to well below 0.01%.
3. Yes, anywhere where the refractive index changes abruptly, there will be significant reflection and refraction effects.
Claude.
image image
Reply
Thread Tools
Similar Threads for: light ray problem
Thread Thread Starter Forum Replies Last Post
light problem.. rhxoehwhfh Advanced Physics 10 Dec28-07 09:50 AM
Light Problem byerly100 Advanced Physics 15 Oct17-06 08:37 AM
Light problem apchemstudent Introductory Physics 2 Apr7-05 12:12 PM
Plz help me in this light problem shaiqbashir Brain Teasers 1 Mar14-05 11:58 AM
Please help me in this light problem!!! shaiqbashir Introductory Physics 1 Mar4-05 12:05 PM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2010 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
