Spinning Motion Around Centre of Gravity
The discussion revolves around the mechanics of spinning motion, specifically why objects like bottles spin around their center of gravity and the implications of forces acting through this point in the context of rotational dynamics. The scope includes theoretical explanations and conceptual clarifications related to physics principles.
  • Some participants question why objects thrown with a twist spin around their center of gravity, suggesting a relationship between the axis of spin and the center of gravity.
  • One participant asserts that any spinning object must have an axis of spin that passes through the center of gravity to comply with Newton's laws, using the example of twirling a bat to illustrate the necessity of applying force to achieve spin around a different point.
  • Another participant recommends consulting a physics book on rotational and translational momentum for further understanding.
  • A later reply distinguishes between the center of mass and the center of gravity, stating that while they often coincide, they are not the same and can differ under certain conditions, such as non-uniform gravitational fields.
Participants express differing views on the relationship between the center of gravity and the center of mass, indicating that there is no consensus on the definitions and implications of these concepts in the context of spinning motion.
The discussion highlights potential limitations in understanding the distinction between center of mass and center of gravity, particularly in non-uniform gravitational fields, and the need for mathematical derivations to clarify the principles involved.
aerobilal
why do bottles or any other things thrown up with a twist always spin about their centre of gravity? Also if all forces pass through centre of gravity of a rocket in space, it will not rotate , even though there is a net moment about any other point except the cg. why
Any spinning object has to have some axis around which it spins, just by the nature of what it means to spin.
The axis of spin has to pass through the center of gravity in order to satisfy neewton's laws. Imagine twirling a big long bat around the endpoint, rather than the middle. You can make it spin like that, but you have to apply a force to do it.
A more detailed explanation is possible, but requires some math. You can usually see a derivation in terms of the sum of the forces in most books on dynamics.
consult a good physics boom on rotational/transational momentum.
An objects spins around its center of mass, not it's center of gravity. These are distinct points that often coincide, but not necessarily. The center of mass is the point that is fix, no matter what the axis of rotation is.
The center of gravity is the point which would have the same trajectory in a gravity field as a the entire body.
They differ when gravity is not constant throughout the object (such as a mountain or a very very tall post).
  • · Replies 32 ·
  • · Replies 133 ·
13K
