How to find all solutions for x in the interval [0, 2pi) for 2cos(3x) - 1 = 0?
  • Thread starter Thread starter lovemake1
    Trig
The discussion revolves around finding all solutions for the equation 2cos(3x) - 1 = 0 within the interval [0, 2π). Participants are exploring the implications of the cosine function and its periodicity in relation to the given equation.
  • Participants discuss the transformation of the equation to cos(3x) = 1/2 and the implications of this transformation on the interval for x. There are questions about how to derive solutions from the cosine function's properties, particularly regarding which quadrants to consider for positive solutions.
The discussion is active with participants sharing their attempts and corrections regarding the solutions derived from the cosine function. Some participants are questioning their understanding of the periodic nature of the cosine function and how it affects the solutions in the specified interval.
There are mentions of potential confusion regarding the intervals and the periodicity of the cosine function, particularly when considering the transformation from 3x back to x. Participants are also clarifying the correct angles associated with the cosine values and their respective quadrants.
lovemake1
Find all solution for x in the interval [0, 2pi)
2cos(3x) - 1 = 0
2cos3x = 1
cos3x = 1/2
since x = [0,2pi)
therefore, 3x is [0,6pi)
so.. here is my problem i know that cosx =1/2 is 1/3pi, and how would i go from here?
will i be adding 1/3pi + 2n pi or just 1/3pi + n pi, and how do we know which one to use?
please help,
i will be refreshing the page frequently to respond to your next suggestion or errors i might have.
please help, thanks
2cos(3x) - 1 = 0
2cos3x = 1
cos3x = 1/2
since x = [0,2pi)
please help,
First you need to find all the solutions from 0 to 2π. Cosine is also positive in quadrant 4, meaning that another solution is 2π-π/3.
So you solutions will be x = π/3,2π-π,3
now when you go around the circle again, you will need to add 2π to all your solutions. Just go around another time and you should get all of your solutions for the problem.
so our goal is to find every positive solution ? meaning for cos = 1/2, quadrant I and IV?
please correct me on this one,
and if it was cos = -1/2 we would find answers from quadrant II and III
as n - 1/2 and n + 1/2, please let me know if my understanding is correct.
Thanks
Thanks
I am not sure what you mean by 'n+1/2', but the part about cosine being negative is correct.
i've found all the solutions for cos = 1/2
pi/3, 2pi/3, 7pi/3, 8pi/3, 13pi/3, 14pi/3, 19pi/3 ( this is greater than 6pi, so excluded)
but since this is 3x not x, which extends the interval from [0,2pi) to [0,6pi]
would we just divide all our answers by 3?
The ones I bolded above are wrong. Those angles are in Quadrant II, not IV. Try again.
Once you fix the above, then yes, you would then have to divide all of the answers by 3.
right, 2pi/3 shud be 5pi/3
and 8pi/3 shud be 11pi/3
14pi/3 shud be 17pi/3
2cos(3x) - 1 = 0
2cos3x = 1
cos3x = 1/2
since x = [0,2pi)
please help,
please help, thanks
Shud not the highlighted be [0,2pi/3)?
No, that would mean you are solving cos(x/3)=1/2
If 0≤x<2π, then 0≤3x<6π
Dear Rock.freak667,
Does not period of a cosine function
y = a cos kx (k>0)
complete one period as kx varies from 0 to 2pi, that's 0<=kx<=2pi or for 0<=x<=2pi/k? For example period of cos 3x is "2pi/3"...
May be I am mixing up two separate things, ...pls explain, eager to understand...
Thanks,
Josh.
  • · Replies 25 ·
  • · Replies 21 ·
  • · Replies 24 ·
