Request advice on right application of NaOH or KOH
The discussion revolves around the use of NaOH and KOH as degreasers in a restaurant setting, specifically addressing concerns about their environmental impact, potential damage to septic systems, and safety when used on various surfaces. Participants explore the implications of using these chemicals in both solid and liquid forms, as well as their effects on plumbing materials.
  • One participant expresses concern about the environmental impact of NaOH and KOH when disposed of down the drain and questions whether landfill disposal is preferable.
  • Another participant mentions that a small amount of NaOH/KOH can be beneficial for corrosion but warns that excessive alkalinity may lead to caustic embrittlement of metal pipes.
  • A suggestion is made to dilute solid NaOH/KOH with a lot of water before disposal, particularly if used in solid form.
  • The original poster describes their dilution practices and the types of surfaces they clean, raising questions about the effects of caustic embrittlement on stainless steel.
  • Concerns are raised about the corrosive effects of NaOH on aluminum and white metal, with a mention of hydrogen gas evolution during cleaning processes.
  • Another participant notes that the flammability warning on KOH products may relate to reactions with amphoteric metals like aluminum, which can produce hydrogen gas.
  • There is a discussion about the safety of using concentrated KOH solutions, particularly regarding their slipperiness and potential for corrosion over time.
Participants express a range of views on the safety and environmental impact of using NaOH and KOH, with no consensus reached on the best disposal method or the extent of their harmful effects on different materials.
Participants mention various dilution ratios and cleaning practices, but there are unresolved questions about specific concentrations, the effects on different materials, and the environmental implications of disposal methods.
nightcleaner
I work in a restauant and use KOH and NaOH as degreasers. Will these damage our septic system if I put them down the drain? Would it be better to send them to the landfill? Is one less harmful to the environment than the other?
Personally I use them as spareingly as possible but I know other workers use them without restraint. Am I just being fussy or is there a good reason to try to minimize the amount used? If there is a good reason to minimize, is there a resource I can use to try to convince my co-workers to be more conservative?
Thanks for any information
nc
Chemistry news on Phys.org
I've got no practical experience in this area, but nevertheless, from a theoretical point of view, here's my five cents worth :
A little bit (much is a little ? ~ 200 ppm) of NaOH/KOH is good, from a corrosion point of view. However, too much (how much ? I don't remember the numbers for this) alkalinity will lead to Caustic Embrittlement (aka Stress Corrosion Cracking) of metal (typically iron/steel) pipes.
I don't know much about environmental effects.
Do you use solid NaOH/KOH? If you use a solution, then it is probably okay to put down the drain with a lot of water, if you use the solid, I would dilute it with a lot of water first.
Thanks for the thoughts. I didn't know that about caustic embrittlement. The cleaning product comes in gallon bottles, is a liquid, and does not state the ppm. I do dilute it and wash it down with lots of water. Our plumbing is all plastic, as far as I know. The building is new, only a few years old. But we have had trouble with the septic.
I dilute the product to about 1:64 for general cleaning, but use it full strength (according to directions) on our nickle grill. I sometimes use it on the stainless steel walls behind the cook line. Does caustic embrittlement affect stainless? It takes the grease off but I don't want to dull the finish.
I do use a solid NaOH product for cleaning out the deep fryer. It is dissolved at about two cups to fifteen gallons of water. After boiling for an hour, I drain the stuff into a mop bucket and use it on the quarry tile floors. It cleans up the grout lines like nothing else I have tried. I have also used it to clean stainless steel vent covers. I have found it to be a bad idea to use it on aluminum or on white metal, as it corrodes those and off-gasses what I presume to be hydrogen gas. No, I havn't tried lighting a match to it.
By the way, the KOH product carries a warning label with the number two under flammability. It doesn't contain any alcohol or organic solvents, so I suppose this has to do with the hydrogen.
Anyway thanks for taking some time in applied science.
nc
That flammability thing is odd. KOH and NaOH aren't really flammable, so it must be something else that is added in there as well. Be really careful when washing floors with that KOH mixture, base solutions tend to be very slippery, especially one as concentrated as that.
From my experience using KOH solutions to clean glassware, you would have to leave the stuff in the base solution for a considerable time before you saw any ill effects. I don't have much experience with cleaning metal surfaces this way though. Regardless, I think that the corrosion reaction is relatively slow, so as long as you rinse everything thoroughly and don't let it sit overnight or anything, you should be fine.
Hello,
The number two under flammability probably discusses the ill effects of KOH with amphoteric metal surfaces like aluminum; as you tried and saw, hydrogen gas evolution along with a considerable corrosion may be present on these surfaces.
Regards, chem_tr
  • · Replies 19 ·
11K
  • · Replies 17 ·
