Calculating the electric field due to a wire of finite length
The discussion focuses on calculating the electric field components (Ex and Ey) at point (x,0) due to a uniformly charged wire of finite length L, positioned vertically along the positive y-axis. The electric field is derived using the equation E = KQ/R², where K is the Coulomb's constant and R is the distance from the charge element. Participants emphasize the importance of breaking the electric field into its x and y components, utilizing the relationships dE = K(dQ/R²) and dQ = λdL, where λ represents the linear charge density. The integration process is highlighted, with suggestions to use a U substitution to simplify the calculation.
  • Understanding of electric field concepts and vector components
  • Familiarity with integration techniques in calculus
  • Knowledge of linear charge density (λ) and its application
  • Basic grasp of Coulomb's law and its constants
  • Study the integration of electric fields from continuous charge distributions
  • Learn about the application of U substitution in calculus for simplifying integrals
  • Explore the derivation of electric fields from different charge configurations
  • Investigate the concept of electric field lines and their significance in electrostatics
Students studying electromagnetism, physics educators, and anyone interested in understanding electric fields generated by charged objects.
aftershock
Suppose a uniformly charged wire starts at point 0 and rises vertically along the positive y-axis to a length L. Determine the components of the electric field Ex and Ey at point (x,0). That is, calculate [tex]\vec{}E[/tex] near one end of a long wire, in the plane perpendicular to the wire.
E= KQ/R^2 with a point charge. So I'll be using integration as well.
Ditching the vector for now and focusing on magnitude I have
dE = K (dQ/R^2)
[tex]\lambda[/tex]dL = dQ (where lambda is the linear charge density)
dE = k[tex]\lambda[/tex]dL/(x^2 +y^2)
pretty much can't figure out how to complete the integration...
dL should be dy
you need to break the E field into components
the y component of the E field is (k*dq)/(x^2+y^2) * sin(t)
the x component of the E filed is (k*dq)/(x^2+y^2) * cos(t)
once you get there, use a U substitution and the integral should be trivial
  • · Replies 18 ·
22K
