Thread Closed
Equal weight
Share Thread Thread Tools
Oct3-10, 01:02 AM   #1
Equal weight
In either the northern or southern hemisphere, what is the maximum difference in latitude between two places measuring the same total centripetal and gravitational accelerations?
PhysOrg.com
PhysOrg
earth sciences news on PhysOrg.com
>> NASA's BARREL mission launches 20 balloons
>> Power of US tornado dwarfs Hiroshima bomb
>> Satellites see storm system that created Moore, Okla., tornado
Oct3-10, 02:22 AM   #2
... it depends on your accuracy/sensitivity. No two different latitudes on one hemisphere have the exact same values.
Oct3-10, 11:55 AM   #3
I thought a standard weight measured over the Earth's surface would vary continuously.
Oct3-10, 02:09 PM   #4
Equal weight
Gravity is also a function of geology, elevation, and time (due to the movement of celestial bodies).
I don't know the answer but I am curious ... Why do you ask the question?
Oct3-10, 07:06 PM   #5
Quote by Loren Booda View Post
For the most part yes, absolutely. The correction due to the centripetal force is pretty simple, and for any given model of oblate-ness, you can correct for that. Most likely variations due to geology (etc) would be entirely negligible, but again, it depends on your situation and sensitivities.
Actually, depending on the particular nature of the obliquity, it is possible that at different latitudes your weight would be the same (finding different balances between centripetal force and variations due to radius and asymmetry)---but it would depend on the particular models.
Oct3-10, 09:45 PM   #6
Quote by billiards View Post
I find it aesthetically intriguing how two most widely separated points would have the same magnitude of acceleration as mapped on the Earth's surface.
Oct4-10, 07:40 AM   #7
Recognitions:
Gold Membership Gold Member
Hmm at this point maybe a reference to Grace would help?
Thread Closed
Thread Tools
Similar Threads for: Equal weight
Thread Forum Replies
In two equal complex numbers, what parts are equal to each other? Calculus 17
error: your goal weight is greater than your starting weight General Discussion 18
Does the normal always equal weight, if on a non-inclined plane? Introductory Physics Homework 3
Numbers in Triangle Rows of 3 are equal rows of 4 are equal Brain Teasers 2
Equal areas in equal times Calculus & Beyond Homework 3
