| Thread Closed |
Problem on Rotational mechanics / Conservation of angular momentum. |
Share Thread |
| Oct8-10, 01:05 PM | #1 |
The figure shows two cylinders rotating about their axes, all the variables involved are shown. The two cylinders are moved closer to touch each other keeping the axes parallel. The cylinders first slip over each other at the point of contact but slipping finally ceases due to friction between them. Find the angular speeds of the cylinders after the slipping ceases. ![]() 2. Relevant equations
I have succeeding in solving the problem by equating the angular impulse due to friction to the change in angular momentums of both cylinders and eliminating friction force from the two equations. But I'd like to solve this using conservation of angular momentum as well since it should be pretty straightforward and easy. Since no external torque acts on the system, conserving angular momentum, I get: [tex]I_{1}\omega_{1}+I_{2}\omega_{2}=I_{1}\omega_{1}' + I_{2}\omega_{2}'[/tex] Using this with w1' * r1 = w2' * r2, I get [tex]\omega_{1}' = \frac{I_{1}\omega_{1}+I_{2}\omega_{2}}{I_{1}r_{2}+I_{2}r_{1}} r_{2}[/tex] and a similar expression for w2'. The answer, however, is [tex]\omega_{1}' = \frac{I_{1}\omega_{1}r_{2}+I_{2}\omega_{2}r_{1}}{I_{1}r_{2}^{2}+I_{2}r_ {1}^{2}} r_{2}[/tex] |
| Oct8-10, 07:58 PM | #2 |
Anyone?
| Thread Closed |
Similar discussions for: Problem on Rotational mechanics / Conservation of angular momentum.
| conservation of angular momentum / finding change in rotational kinetic energy | Introductory Physics Homework | 11 | ||
| Conservation of Angular Momentum problem | Introductory Physics Homework | 2 | ||
| Rotational mechanics and Angular Momentum- help needed to check over work | Introductory Physics Homework | 1 | ||
| Conservation of Angular Momentum Problem Help | Introductory Physics Homework | 1 | ||
| Conservation of angular momentum problem | Introductory Physics Homework | 2 | ||
