| Thread Closed |
I am looking into calculating the weld bead strength. I am unsure of |
Share Thread | Thread Tools |
| Oct8-10, 06:49 PM | #1 |
I am looking into calculating the weld bead strength. I am unsure of calculating the shear stress..the attachment has a drawing..any help is appreciated
| Oct14-10, 12:15 PM | #2 |
Recognitions:
vanuta: (1) Is angle beta in the xy plane? Or not in the xy plane?
(2) Why do you call alphay a normal stress, when it looks like you are using a shear force, F*cos(beta), to compute alphay? (3) Why do you use cos(beta) to compute alphay? (4) I am not yet confident that you have drawn the applied force, F, as it really occurs on the real assembly. Please draw a correct, quick, freehand sketch of the assembly, showing how and where the applied force(s), such as F, are really applied. And show the x, y, and z dimensions to the point of application of the applied force(s) (and applied moment(s), if any), so that we can really see how your joint is loaded. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: I am looking into calculating the weld bead strength. I am unsure of
| How to weld aluminum foil? | Mechanical Engineering | 10 | ||
| Stress due to bending of fillet weld joint | Mechanical Engineering | 5 | ||
| Lap fillet weld bending | Engineering Systems & Design | 3 | ||
| Why can't you TIG weld Aluminium with DC current? | Chemistry | 2 | ||
