Calculate Work to Drain a Hemispherical Tank
  • Thread starter Thread starter Punkyc7
    Tank Work
The discussion focuses on calculating the work required to pump water out of a hemispherical tank with a radius of 2 inches, filled to a depth of 1 inch. The work is derived using the formula W=FD, where F is the force due to the weight of the water and V is the volume of the water. The correct integration approach involves determining the volume of a water layer at depth z and integrating the work done from z = -2 to z = 0. The final answer should yield 9ρπ/4, contrasting with the incorrect result of 11πρg/3 presented by one participant.
  • Understanding of calculus, specifically integration techniques.
  • Familiarity with the concepts of force and work in physics.
  • Knowledge of the geometry of hemispherical shapes.
  • Basic principles of fluid mechanics, including density and pressure.
  • Review integration techniques for calculating volumes of revolution.
  • Study the principles of work and energy in fluid mechanics.
  • Explore the application of calculus in real-world physics problems.
  • Learn about the properties of hemispherical tanks and their applications in engineering.
Students in physics or engineering, mathematicians interested in applied calculus, and professionals involved in fluid dynamics or tank design will benefit from this discussion.
Punkyc7
a bowl shaped tank is in the shaoe of a hemisphere with a radius of 2 in. If the bowl is filled with water density rho to a depth of 1 in, find the work in pumping the water out fo the tank
W=FD
V=integral of surface area * height
F= rho *V
V is the integral of pi(sqrt(4-y^2))^2 from 0-1
D=2-x
so W=rho*V int 2-x from 0-1
i get 11pi rho g/3 and the answer is suppose to be 9 rho pi/4
im not sure where i am going wrong but i thing it has to do with my integration
Assume that your hemi-spherical bowl has its flat surface in the xy-plane and the center of that surface at (0, 0, 0). Then [itex]x^2+ y^2+ z^2= 4[/itex]
Now, imagine a "layer" of water at depth z (z< 0), of thickness "dz". The boundary of that layer is the circle [itex]x^2+ y^2= 4- z^2[/itex] which has radius [itex]\sqrt{4- z^2}[/itex] and so area [itex]\pi(4- z^2)[/itex] and volume [itex]\pi(4- z^2)dz[/itex]. The weight of that water is [itex]\pi\rho g(4- z^2)dz[/itex] and we must lift it a height -z (remember that z is negative) out of the bowl. The work done is [itex]-\pi\rho g(4- z^2)dz[/itex].
Integrate that from z= -2 to z= 0.
  • · Replies 16 ·
